![]() Join Date: Nov 2010
Rear end questins
I had a question on a rear end for a 63 c10. We pulled it all apart and the ring and pinion are shot, blew out in 68 according to the date codes but there are 41 to 11 on the teeth. My question is where is the best place to find a new rear end kit? or where have people gotten it before? And also if anyone knows that that gear ratio would be thatd be helpful. Any info will help thanks
#2 | |
Re: Rear end questins
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
captain fab had some links for a similar question link:
http://67-72chevytrucks.com/vboard/s...d.php?t=481683
http://www.csgnetwork.com/rnggrpinioncalc.html
3.73 I bought mine from LMC. It might be smart to also buy the inner/outer pinion bearing raice's and seal. It all depends when you get it apart how bad they look. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
summit racing, best pricing
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Well the plan is to get a master kit if possible. bearing seals gears everything
