![]() Join Date: Oct 2009
Looking for cheap, broken, cracked, chipped a/c vent ball housings
This might sound a little weird, but I'm looking for a rt & lt vent ball housing to use as a template. I want a set that's basically not good enough to use. Thanks!
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
VA72C10
![]() Join Date: Mar 2008
Re: Looking for cheap, broken, cracked, chipped a/c vent ball housings
ttt for you. I might have a broken useable set for a template but likely will be a while before I can get to the box to look for them so hopefully someone else has a set....or has a template for you...I remember seeing one on the board in the FAQ section likely?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Thanks! I have templates, but I want the most assurance possible before I do any cutting. I'm essentially going to cut the connector off of the back of the housing so it will sit flush against the dash.
if the template ends up being correct after all is said and done, please let me know where you got it..
