Like the title asks, how low could I go without cutting/notching the frame on a 2wd.
Posted via Mobile Device |
Re: No C-Notch, How Low???
I had a 4/6 and it worked just fine. I never bottomed it out. Works fine on these south Texas roads.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
I have 4" drop springs and 1 3/4" blocks in back of a factory 2wd, that leaves me 1 1/2-3/4 between diff and frame; it bottoms out LOTS and may get a notch yet!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
![]() Join Date: May 2005
Same as El Campo here. Early Classic 4/6 drop on my C-10, no C notch, and never bottomed out yet.
I'm not sure if there's any difference between a truck and blazer frame...
needs more $$$
I had a 4/6 on mine without a c-notch when I bought it. It bottomed out on me twice with no one in the back, but with passengers back there it happened a lot more often.
1970 2wd Blazer |
Hmm interesting. Maybe there is more difference in the truck to blazer frames than I realized. I too have the ECE 4/6. I ended up C notching mine recently anyways. Used a piece of pipe to do it as I don't like the homemade looking ones that you buy that you bolt or weld in.
needs more $$$
I think it has to do more with weight rather than dimensions. I had the top on when it bottomed out with no passengers (and a fairly big bump while getting on the freeway), and then after that had about 350 lbs of guys right over the axel...I'm sure if you did that with a truck you'd be in the same boat.
1970 2wd Blazer |
