07-08-2012, 11:43 PM | #1 |
425hp409
Serpentine Belt System Help
I am installing a GM serpentine belt system on a customers 72 C10 2WD and I have a problem with the lower radiator hose. There is no room for a hose to clear the frame under the aluminum bracket that the AC Compressor and Belt Idler are attached to. The original hose wont fit without kinking, and I tried a hose for an 89 C10 with a serpentine system, but it won't fit either. I am thinking that if no one can help me that I might have to make a pipe to go over the frame with a hose at both ends. Anyone who has solved this problem, I would appreciate the help.
Charles
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
07-09-2012, 08:24 AM | #2 |
Re: Serpentine Belt System Help
Put two of these on myself. The stock lower hose will work with a slight kink you are right but have ran that this way. But after a few hrs working with it i have about 95% of any of the kink out. If you are concerned about the kink your best bet would be to make a curved pipe like you mentioned or remove a portion of the serp bracket with a cutting wheel. That would be the only way to clear the frame without the kink.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
07-09-2012, 08:30 AM | #3 |
I used the bendable corrugated chrome type hoses that only have a small piece of rubber at both ends. I am not positive but I think they help in cooling too. Just cause my 406 has never overheated.
You ARE talking about a stock 1992 or so serpentine system?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 07-09-2012 at 08:43 AM. |
07-09-2012, 11:08 AM | #4 |
I "relieved" both the frame and the bottom of the bracket just enough to get most of the kink out and still used the stock hose.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-09-2012, 12:19 PM | #5 | |
425hp409
Charles
07-09-2012, 01:05 PM | #6 |
Looks like a Be Cool hose kit, they can be found online or they are always for sale at the bigger shows with vendors.
I would just use a piece of tube and the factory hose as ends. I just did this on my 71, I swapped in a 454 out of a 96 3500, and the outlets and inlets didn't match, so I build an adapter after trying about 3 different hoses. |
07-12-2012, 12:31 AM | #7 |
425hp409
i decided to use a piece of tubing in the middle of the hose.
