07-09-2012, 09:56 AM | #1 |
Throtle by wire on old accelerator ?
I have a 6.0L from a 2004 HD and it had throtle by wire. has anyone modified the old accelerator to work with this or can you show pictures of how you mounted the accelerator ?
07-09-2012, 12:10 PM | #2 |
meowMEOWmeowMEOW
Re: Throtle by wire on old accelerator ?
Not an option, you need to get the correct pedal and tac module to match the pcm and tb on your truck. The mechanical linkage can only be used if you switched over to drive by cable.
07-09-2012, 01:26 PM | #3 |
i have both the accelerator and the tach module. i was just thinking that there was a way to mount the throtle position sensor on the old style accelerator
07-09-2012, 07:48 PM | #4 |
Some of us have attached our pedals to the DBW pedal assembly.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-09-2012, 08:10 PM | #5 |
Here is how I did mine and used the stock pedal.
http://67-72chevytrucks.com/vboard/s...d.php?t=300335 Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-14-2012, 10:34 PM | #6 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-14-2012, 11:14 PM | #7 |
Truck and auto performance nut
can't see the electronics.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-26-2013, 01:41 AM | #8 |
This is an old posting, but I have a question about modifying DBW pedals. Using a 2003 Tahoe into my 55 suburban. Can I shorten the lever arm so it fits better? Do you have to use the entire swing of the pedal? If I set the pedal up where I use the entire swing, it is to high and uncomfortable when in the up position.
Posted via Mobile Device |
02-26-2013, 06:32 PM | #9 |
meowMEOWmeowMEOW
^I went through this as well. I ended up cutting a new arm (my gas pedal is actually a shotgun barrel, but thats a long story)..the length I wanted, and then attaching that to the old base/sensor assembly. Its doable, just don't heat the base up too much or you can fry the sensor (it comes off if you want to be safe.
As far as the sweep...we didn't really figure out a way to change that, though maybe in the tune? With the angle my pedal arm is at, it uses the full sweep, yet sits tight to the floor giving max leg room.
