Old 07-09-2012, 11:09 AM   #1
blazer2007
is there a better stock brake caliper ?
On a 80,s 1/2 ton truck is there a better caliper other than the single piston stock type that can bolted on without getting a new spindle
blazer2007 is offline   Reply With Quote
Old 07-09-2012, 12:22 PM   #2
canadian trucker
A day should have 30 hours.
Re: is there a better stock brake caliper ?
I believe Wilwood makes an upgrade
1.25" wide front Rotor
http://www.wilwood.com/BrakeKits/Bra...olet&model=C10 Pickup&modoption=4 x 2 w/ 1.25 Wide Front Rotor
1.00" wide front Rotor
http://www.wilwood.com/BrakeKits/Bra...olet&model=C10 Pickup&modoption=4 x 2 w/ 1.00" Wide Front Rotor
Will bolt up using oem spindles and rotors.
canadian trucker is offline   Reply With Quote
Old 07-09-2012, 11:23 PM   #3
andrewmp6
wilwood makes a 2 piston caliper that a bolt on replacement for the d52 http://www.wilwood.com/Calipers/Cali...0Dual%20Piston
andrewmp6 is offline   Reply With Quote
Old 07-10-2012, 09:46 AM   #4
blazer2007
thanks ,perfect.
Old 07-10-2012, 10:52 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Check our Suspension and Vendor Marketplace for great deals on the Wilwood D52 caliper. You will be happy that you did.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
