Old 07-09-2012, 03:09 PM   #1
DT1
DT1's Avatar
Quadrajet float bowl leaking down
I have always had a problem with my Quadrajet leaking down after sitting for more than two days. After I depress the gas pedal to set the choke, I have to crank the starter for at least 5-7 seconds to allow the float bowl to fill. When it finally starts, I get a big puff of rich black smoke for a second.
I sealed the bottom well plugs with Cliff Ruggle's kit but it didn't solve the issue.
Does anyone have any other suggestions to fix the problem. The only thing I can think of is that the float valve isn't seating properly. Maybe the power piston spring is too light?
Any suggestions would be appreciated.
DT1 is offline   Reply With Quote
Old 07-09-2012, 04:39 PM   #2
cdowns
cdowns's Avatar
Re: Quadrajet float bowl leaking down
craking a starter for 5-7 seconds has always been normal on the old vehicles i've owned
Old 07-09-2012, 06:02 PM   #3
RustyBucket
RustyBucket's Avatar
Have you got a good squirt on your accelerator pump?
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 07-09-2012, 06:28 PM   #4
mMad Dawg
Just a thought,but did you happen to check your fuel pump ( mechanical ).If the diaphram in them has a slight leak the gas will drain uot of the carb. Usually into the crankcase. Hope this helps Gord
mMad Dawg is offline   Reply With Quote
Old 07-09-2012, 09:52 PM   #5
Lee H
Lee H's Avatar
5 - 7 seconds is about right. Try to pump the accelerator as you crank, may knock off a second or two.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-09-2012, 10:10 PM   #6
asolde
asolde's Avatar
I have to crank 5-6sec before it fires off. I think its either my carb float or my fuel pump. I am changing my pump first Bc I have my engine out right now.
asolde is offline   Reply With Quote
Old 07-09-2012, 10:10 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
"Leaking down".....you're saying that because of the cranking time. But, you know that the float bowls have a couple of plugs that are prone to leaking over time, right? If so, you will know that it will run rich because fuel will leak into the manifold, and flooding will become more common. It's one of the few things I don't like about Q-Jets, but it wasn't enough to keep me from buying a new one.
With Fuel Injection systems, starting is quicker. So, we tend to judge how well these older non-FI engines start, when they actually do very well.
My '69 350, when cold, required me to pump the pedal to set the choke, then I would bump the key and it would burst to life!
Member Nr. 2770
Old 07-10-2012, 09:45 AM   #8
DT1
DT1's Avatar
I sealed up the plugs on the bottom and can absolutely state that they are not leaking. If the float bowl has fuel in it and everything else is adjusted properly, five to seven seconds is an eternity. If there is enough fuel in the bowl to allow the accelerator pump to give a shot and the choke is properly set the engine should come to life almost immediately. I'm still leaning on the float valve. This weekend I will remove the carburetor and fill the bowl with gas and let it sit on the bench for a day or two just to see if I'm loosing gas through the valve.
Old 07-10-2012, 01:00 PM   #9
Lee H
Lee H's Avatar
Originally Posted by DT1 View Post
......the accelerator pump to give a shot and the choke is properly set the engine should come to life almost immediately.
Even with all systems tuned and set up properly, with this 40 some odd year old technology, this is not going to happen. It may start a little quicker with HEI but still not "almost immediately".
Old 07-10-2012, 01:04 PM   #10
DT1
DT1's Avatar
With all due respect...Some may not start "Almost immediately" but mine does.
Old 07-10-2012, 01:05 PM   #11
Coley
Coley's Avatar
Smile Re: Quadrajet float bowl leaking down
Check and ensure that your (carb fittings) fuel filter is the 'check' valve type and not the bronze 'cup' style.
The check valve type helps keep the fuel up in the carb to help facilitate faster start up, particularly on 'cold' starts.
Good luck, Keep us posted.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 07-10-2012, 08:04 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If you're carb is "leaking down" then I'd take a smell of the engine oil. That fuel will go from the manifold to the cylinders and leak past the rings and end up in the oil pan. If your oil smells like raw fuel... that would be bad.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-11-2012, 09:45 AM   #13
DT1
DT1's Avatar
Coley
Thanks. I'll check that. I got to thinking and I'm wondering if this has anything to do with the reformulated (Oxygenated) fuel. Just a hunch but maybe it evaporates faster??
Old 07-11-2012, 02:10 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Check or replace the needle valve and seat. Even if it's new it can still leak. That's what keeps fuel in the bowl from seeping back to the pump.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-11-2012, 02:30 PM   #15
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
not sure if it does, , I had mine rebuilt and tuned before I installed it. The P/O had too small of an edelbrock on it that wasn't working right. but mine would start the same after a few days or a week.
Key on, electric choke, two pumps and with in 2 seconds it would fire up.
I think I cut it down to 1 after I installed the H/T starter.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
