Old 07-09-2012, 05:41 PM   #1
808486CHEVY
808486CHEVY's Avatar
anyone have blueprint for flip kit?
surely someone has the measurements for the basic flip kit??? Here is a pic of whT Im lookin for. I hate to spend $50 for something I can make in 20 Minutes.
808486CHEVY is offline   Reply With Quote
Old 07-09-2012, 07:10 PM   #2
Project82
Bretzke Racing Inc.
Project82's Avatar
Re: anyone have blueprint for flip kit?
Sorry no blueprints, but my 2 cents, i thought the same thing, why spend the money when i can make them??? i wanted to make a set but i didnt think that it would hold up to the weight of the ass end...so i forfeited the 85 dollars to a DJM kit and got the well needed shock extension brackets. those came in handy especially since i just bought new stock rear shocks when i did my flip kit. if i would've made the flip brackets i would have to buy dropped shocks....i really had to weigh some options. not saying i dont trust my work but if its readily available, why waste the time???
making a set isn't that bad either, if you wanna buy drop shocks and you have a welder and grinder and time, go for it...but i would buy the kit.
find some thick flat bar steel and a nice auto-darkening welding helmet.
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic
Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear)
2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic
Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12
"Expect the Un-expected"
"Gas, Grass, Or Ass...No one rides for FREE!"
Project82 is offline   Reply With Quote
Old 07-09-2012, 08:05 PM   #3
J Knight
J Knight's Avatar
Here are the dementions for the flip bracket, dont have them for the shock extenders but the inside demention of the extenders are the same as the outside dementions of the factory shock mount if you want to try and build those too.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-09-2012, 10:38 PM   #4
grs
Where did the shock extenders come from?
grs is offline   Reply With Quote
Old 07-09-2012, 10:45 PM   #5
mongoose
mongoose's Avatar
djm kit...
tho my dkm flip kit didnt fit worth a damn so..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-09-2012, 11:31 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Haha neither did my flipkit! Djm is good for that supposedly. I just welded mine taller and they fit
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-10-2012, 12:17 AM   #7
J Knight
J Knight's Avatar
I installed two of these kits last year with no problems, what could possibly different between the kits and 1/2 ton rear axles not being uniform?
John
Old 07-10-2012, 12:41 AM   #8
Square_78
Square_78's Avatar
My kit fit perfect. Shock extenders slid right on and bolted right up easy.
Square_78 is offline   Reply With Quote
Old 07-10-2012, 01:10 AM   #9
gGMC DOG
flip bracket blueprint pdf format. lot better than the picture of mine that john is using.
http://67-72chevytrucks.com/vboard/s...&postcount=368
gGMC DOG is offline   Reply With Quote
Old 07-10-2012, 01:16 AM   #10
gGMC DOG
also brothers sells shock extenders, and they're made by beltech. a lot beefier than the ones from djm
Old 07-11-2012, 08:56 AM   #11
808486CHEVY
Thanks alot guys thats exactly what I was lookin for. Much appreciated
Old 07-11-2012, 01:12 PM   #12
1BadAction
1BadAction's Avatar
Will this also work on newer trucks? Like 88-98 or 99+?
What size U-bolts are needed?
2010 Basalt Black Porsche Cayenne GTS - Daily driver
1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again.
1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
1BadAction is offline   Reply With Quote
