Old 07-09-2012, 06:14 PM   #1
hfd410
hfd410's Avatar
stock coil springs
Im doing a frame off on my 71 super cheyenne SWB. I have stripped and POR15 treated frame with all new front end stuff. I ordered stock coils but really want to drop it a little. I have had the coils for a long time so cant exchange em. So the question is how much to cut for 1 1/2 or 2 inches? What coils for rear to level it? Thanks in advance.
71 Super Cheyenne SWB
Ochre/white
parchment interior
hfd410 is offline   Reply With Quote
Old 07-09-2012, 06:49 PM   #2
69gmcc10
69gmcc10's Avatar
Re: stock coil springs
start by cutting 1/2 a coil on the front springs and drive it around a few days to allow the spring to settle and see if you like the height. If you want it lower cut another half off and drive it around again to settle the spring again. I know it sounds like allot of work, but you will get the height you want. On the rear just block it with a 2 inch block, it's cheap and easy.
69gmcc10 is offline   Reply With Quote
Old 07-09-2012, 07:27 PM   #3
hfd410
hfd410's Avatar
Thanks alot !!
Old 07-09-2012, 08:08 PM   #4
duallyjams
duallyjams's Avatar
Just use lowering blocks on the rear that way you can use the springs that you already have and IMO I would cut just one coil off of the front.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
