07-09-2012, 06:18 PM | #1 |
1990 Blazer code 32
Recently the "service engine soon" light came on my 1990 Blazer. I scanned for codes using the paper clip method. I got a code 32 (EGR SYSTEM). So I put in a known good, working, negative backpressure EGR Valve from a different TBI Blazer, which did run good before I pulled the EGR Valve. I drove it around that day with no more SES light. Yesterday I was driving it and the SES light came on again. So I scanned for codes again and got code 32. I have noticed that I have been getting bad gas mileage and a foul smell from the exhaust (which has no catalytic converter present.) The truck also has a new Delphi IAC Valve. The engine runs good and has plenty of power, no hesitation or bucking and the injector spray pattern looks very good.
07-17-2012, 12:56 AM | #2 |
Re: 1990 Blazer code 32
Fixed the problem myself. Thanks everyone.
07-17-2012, 01:22 PM | #3 |
So what was the solution to your Code 32 problem - EGR related codes are PITA to figure out sometimes.
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
07-17-2012, 02:23 PM | #4 |
I replaced the EGR valve, then I reset the ECM. SES light stopped coming on.
08-29-2012, 11:14 AM | #5 |
How do you reset the ECM?
I got a 32 code too. Going to replace the EGR valve and hopefully that will fix it. |
