Old 07-09-2012, 08:30 PM   #1
Stew_Magoo
Easy access to inside of heater box?
I'm looking to get into my heater box to clean it out. Temp control lever doesn't move easy, doesn't travel through the full temp range, and I'm getting a lot of heat with the temp control at almost full cool, mode lever set to off. The cable is hooked up to the door, and does move, but i don't believe it is moving full travel, I see no signs the cable is slipping in the clip that holds it to the lever for the door. I feel strongly I have a mouse nest inside my heater box. Truck spent quite a few years as a water truck on a tree farm, I have found countless mouse nests, droppings, radio ruined by mouse piss, and one dead mouse in the truck.
So, what is my best bet for getting inside the heater box? Take the whole AC box out from under the hood? That looks like a PItA, but if that is my only option, then so be it. Also, I have no desire to go hacking a whole in the heater box in the cab.
Truck is a 1990 crew cab with AC and a 454.
Thanks,
-Stew
Stew_Magoo is offline   Reply With Quote
Old 07-09-2012, 08:46 PM   #2
tucsonjwt
Re: Easy access to inside of heater box?
85gmcguy did an excellent post with pictures of the heater/heater control repair including new heater core. Just scroll down for a while until you get to the part you need.
http://67-72chevytrucks.com/vboard/s...r+core+removal
tucsonjwt is offline   Reply With Quote
Old 07-09-2012, 10:28 PM   #3
grs
Nice post
grs is offline   Reply With Quote
Old 07-10-2012, 10:27 AM   #4
crazeetxn
crazeetxn's Avatar
You beat me to it! I used this one to change the blend door actuator and heater core since I was in there.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
