Old 07-09-2012, 10:10 PM   #1
'65 chevy lover
Brake Master cylinder question
When I purchased this latest truck, I was going to put disc brakes on but, decided to leave it drums( with power ) all way around for now. Question is: Will the mastercylinder/booster with proportion valve still work?
Thanks,
'65 chevy lover is offline   Reply With Quote
Old 07-10-2012, 12:53 AM   #2
Captainfab
60-66 Nut
Re: Brake Master cylinder question
If you are talking about using a disc/drum master cylinder with a drum/drum system, I can't say for sure how it will work. Why not just switch the master cylinder to a drum/drum unit and eliminate the proportioning valve. That way you know it will work. Rebuilt or new master cylinders aren't that expensive.
Old 07-13-2012, 06:45 PM   #3
'65 chevy lover
Thank you for the info Captainfab.
Old 07-13-2012, 09:21 PM   #4
CRGRS 66
CRGRS 66's Avatar
a reman master for a 67 impala drum/drum will do the trick, $23 from advance auto parts, and others I am sure
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
