Old 07-10-2012, 02:37 AM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Question Transfer Case ID
How do I tell what transfer case my truck has in it? Thanks.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 07-10-2012, 04:27 AM   #2
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: Transfer Case ID
there is a tag on the back side where you put the fluid in. if its gone. 81-87 had 208 they had a alum. case then 73 -80 had 203 and 205. 203 are full time so your drive line never stops moving they were in i think 73 - 75 i think, then they went to they 205 which is what most guys like.
bowtiemanchevyman is offline   Reply With Quote
Old 07-10-2012, 11:49 AM   #3
Car'n'Guitars
Okay so my truck probably has a 208 then because it is a 85.
Old 07-10-2012, 11:50 AM   #4
Car'n'Guitars
How do I tell if it is a 208?
Old 07-10-2012, 12:40 PM   #5
bowtiemanchevyman
look at it. if it look like Aluminum its a 208 plus theres a tag on the back side where u put in the Fluid, a 208 uses ATF no gear lube. if u put gear lube in u will burn up the pump in side.
Old 07-10-2012, 12:42 PM   #6
Car'n'Guitars
Couldn't tell by looking it is covered in dirt and grime, I'll have to find the tag.
Old 07-10-2012, 12:44 PM   #7
bowtiemanchevyman
her is a [ic of the case and the id tage.
Old 07-10-2012, 12:46 PM   #8
Car'n'Guitars
Okay thanks that helps me a lot. I'll look a little later.
Old 07-10-2012, 12:50 PM   #9
bowtiemanchevyman
oh ya what is the way the gears are lind up, 2H 4h N 4l what order, and when u put it in N or 4L do you push over to the right or not
Old 07-10-2012, 12:53 PM   #10
Car'n'Guitars
Can't remember I'll go look, I haven't got to drive the truck beside around the yard because it's a project.
Old 07-10-2012, 01:00 PM   #11
Car'n'Guitars
Yeah my truck is 4L N 4H 2H.
Old 07-10-2012, 01:19 PM   #12
bowtiemanchevyman
so 2h is all the way back toward the seat, with 4L towards the dash
Old 07-10-2012, 01:21 PM   #13
Car'n'Guitars
Nope it shows at the top towards the dash.
Old 07-10-2012, 01:22 PM   #14
bowtiemanchevyman
so 2h is toward the dash, if so its a 208
Old 07-10-2012, 01:24 PM   #15
Car'n'Guitars
Here is the order from the seat to the dash, 4L N 4H 2H.
Old 07-10-2012, 01:25 PM   #16
bowtiemanchevyman
ya its a 208. make surre u put ATF in it if you fill it up nothing else.
Old 07-10-2012, 01:26 PM   #17
Car'n'Guitars
Okay thanks for your help, do I use the same as the transmission uses?
Old 07-10-2012, 08:08 PM   #18
bowtiemanchevyman
is it a auto? if so yes.
Old 07-10-2012, 08:11 PM   #19
Car'n'Guitars
Yeah it's a auto TH700R4.
