Old 07-10-2012, 06:07 AM   #1
blackbear
Thumbs down 5 lug axles
took five lug axles out of a 1972 c 10 and put them in my 65. a guy said he put drums off of a chevy van (not sure of the year)witch are wider and it worked fine.did anybody out there try this .never seen anyone on here talk about this.
blackbear is offline   Reply With Quote
Old 07-10-2012, 06:35 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 5 lug axles
The 72 axles themselves are wider than the 65 axles.
I'm not sure I want to have the axle hanging out farther than it's suppose to.
Got any pics of this mod?
Keith
Convert to disc brakes.
Old 07-10-2012, 08:27 AM   #3
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: 5 lug axles
it's been discussed before, others have done it. it's apparently functional but I'm not convinced that everything is lining up, brake shoe-wise and bearing-wise.
Larry
fleetsidelarry is offline   Reply With Quote
Old 07-10-2012, 04:05 PM   #4
blackbear
Re: 5 lug axles
i dont have any pics but i am going to get some old hubs and mock everything up to see what i have.dont know how to post pics.
Old 07-10-2012, 07:26 PM   #5
kgmunro
Re: 5 lug axles
subscribed!
kgmunro is offline   Reply With Quote
Old 07-10-2012, 08:11 PM   #6
McCoyAZ
McCoyAZ's Avatar
Re: 5 lug axles
The 72 axels are about 3/4 of an inch longer on both side I think aren't they?
McCoyAZ is offline   Reply With Quote
Old 07-11-2012, 01:35 AM   #7
Captainfab
60-66 Nut
Re: 5 lug axles
The '71-'82 12 bolt axles are 3/4" longer than the early '70 and earlier axles. Consequently the axle bearing is going to be riding in a different place, which it may not be completely on the machined surface. That depends on the axle. Plus you will have more axle out past the bearing. Then you have the issue of the drums not covering the shoes completely. Regarding the drum issue, you could run the drums for the 2-1/2" wide shoes which started in the mid 70's. But they would still be 1/4" short of covering the brake shoes. Making this work correctly just seems like a whole lot of messing around, and not really gaining anything over either plugging and re-drilling the existing axles, or just buying the conversion axles.
Old 07-11-2012, 01:41 PM   #8
Middleagecrisis
Re: 5 lug axles
So I can take the '68 12-bolt I have and take the 5-lug axles and drum brakes out and swap into them into my existing '62 12-bolt?
Middleagecrisis is offline   Reply With Quote
Old 07-11-2012, 04:21 PM   #9
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 5 lug axles
While we're on the subject of axles.
Will a mid '80's 10 bolt 5 lug axle fit in my mid '70's 12 bolt 5 lug axle.
I was informed by a guy following me that my wheel was going to fall off.
Turns out the flange is bent....Strange ..no shake or vibration.
Thanks ,Trent
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-11-2012, 05:45 PM   #10
fleetsidelarry
Senior Car Nut
Re: 5 lug axles
first off, '68s didn't come from the factory with 5 lug hubs, 5 lugs didn't start 'til '71. so you either have an entire rear end from a '71-'72 (direct bolt-in), someone has done what the OP is talking about or you have redrilled or replacement axles.
I also didn't think '62s had 12 bolts but even so, the early 12 bolts had a different spline count.
Larry
Old 07-12-2012, 12:00 AM   #11
Captainfab
60-66 Nut
Re: 5 lug axles
In addition to what fleetsidelarry said, the truck 12 bolt did not come out until '63. The '63 and '64 12 bolts used 17 spline axles. The '65 and up 12 bolts used 30 spline axles. So if you are wanting to put 30 spline axles into a '63 or '64 12 bolt, you will have to also change the side spiders to the 30 spline pieces. If you do indeed have a '68 housing with 5x5 axles, they must be aftermarket or plugged and re-drilled originals. That is unless someone has done as the OP is asking about, and installed the longer axles into a shorter housing.
Old 07-12-2012, 12:05 AM   #12
Captainfab
60-66 Nut
Re: 5 lug axles
I have heard that the 30 spline axles in the '80-'86 8.5 10 bolts will interchange with the late 70 to '82 12 bolt axles. However I have not tried this, so I can not confirm that is does work. The length should be the same, but I believe some of the 8.5 10 bolt axles are 28 spline?
Thanks ,Trent
Old 07-12-2012, 08:56 AM   #13
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 5 lug axles
Thank you Cpt
I guess I'll be the guy to check that out.
I'll let us know if it flies or not
T
member#7816
'61 GMC in progress
Old 07-12-2012, 08:58 AM   #14
Middleagecrisis
Re: 5 lug axles
Thanks Fleetsidelarry and Captainfab, this kind of knowledge is why I come to this site! I was told the 5-lug 12 bolt rearend came out of a '68 chassis when I bought the 5-lug suspension. Given the age of my '62, no telling what's been swapped into it over the years. I know the 5-lug rearend has a posi in it, so I'll pull them both apart and see what I've got regarding gear ratios and overall condition.
Old 07-12-2012, 09:02 AM   #15
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 5 lug axles
30 spline I believe was 89 up. Other than that they were 28 spline.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
