Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 07-10-2012, 12:33 PM   #1
OJ1988
Just a car guy
OJ1988's Avatar
Avoid American Autowire Alternator conversion
I ordered an external to internal regulator wiring conversion kit by American Autowire. Installed it, and installed the new alternator.
After connecting the battery cable, the alternator started smoking.
I ended up cutting the conversion plug open that connected to the external regulator wiring.
According the posts on this site, you only jump the two outside wires together. The conversion had this, but also had the two wires in the middle jumped together.
The white wire, at the alt, which is supposed to be unused, was going to plug 2 on the alt.
According to this site, plug 2 should be jumped to the post on the alt.
Luckily this only destroyed the alternator, and did no cause any damage to the truck.
I pulled it off, and rewired based on the posts I have seen here. Its good now.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 07-10-2012, 12:39 PM   #2
AirSpeed
AirSpeed's Avatar
Re: Avoid American Autowire Alternator conversion
I found a simple way to wire it right at the regulator plug, someone on here posted a how to for this and it worked perfect and cost nothing, except for the new alternator of course. Took about two minutes to cut and splice a couple wires.
AirSpeed is offline   Reply With Quote
Old 07-10-2012, 01:00 PM   #3
OJ1988
Just a car guy
OJ1988's Avatar
After going through this, I found the thread here that showed how to do it as well.
1973 Vega Drag Car
1970 C20 tow rig
Old 07-31-2012, 07:34 PM   #4
fixit-p
fixit-p's Avatar
The American Auto wire kit didn't kill your alternator, something else did. If the center two terminals are jumped together (red and white wires) then the whit wire should absolutely go to the #2 terminal. And the outside 2 terminals (brown and blue wires) go to #1 terminal. If you look at the diagram below and follow the wires from the back of the alt you will see the #2 wire and the batt wire both connect at a buss (circled) this take advantage of the alternators ability to sense voltage remotely and is more efficient than just jumping the wire to the back. The colors at the alt in the drawing differ from what you had but that is only because the jumpers on the drawing are from 1-3 and 2-4 the only thing that matters is that the brown wire ended up at #1 on the alt and the red wire at #2.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-31-2012, 09:15 PM   #5
All I know is I bought an American Auto Wire HEI tach harness and the plug they put on for the tach connection is the wrong one. It won't plug in w/o modifying...so what's the point? I've made my own tach harnesses until this one. I was just hoping for a factory look. It's enough for me to go elsewhere for my wiring needs.
Old 08-01-2012, 01:08 AM   #6
slikside
slikside's Avatar
Subscribed......first bad rap i've heard about AAW.
Most seem to love their full wiring harness kits.
slikside is offline   Reply With Quote
Old 08-01-2012, 01:41 AM   #7
leddzepp
Moderator
leddzepp's Avatar
ive never had an issue with americanautowire. i have used their headlight, engine, cab, tach, and speedwarning harnesses, and they are all identical to OEM in every way.
tim- what was wrong with your HEI tach harness? mine have all had the correct wiring and firewall grommet. perhaps they sent you one with the OEM horseshoe connector? thats all i can figure, the HEI one i have from them is the correct plugstyle connector and hooked up with no problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-01-2012, 07:31 AM   #8
I'd have to show you a picture,probably. But,the connector is "almost" right. It just won't push into the cap. There is a rib on the distributor side of the connector that keeps it from working. I'll have to shave it off. It could be worse,but just darned aggravating trying and trying to click it in leaning over the engine before realizing it just won't go. I just changed the cap and it still won't go. I'll change my mind,but right now they're on my bad list.
Old 08-01-2012, 10:25 AM   #9
OJ1988
Just a car guy
OJ1988's Avatar
All I know is I pluged mine in, connected the battery cables, and the alternator started smoking. Disconnected it, verified installation, got new alternator, connected battery cables, and smoked another one.
Removed it and wired according to thread here, got new alternator and its all good now, no smoke.
1973 Vega Drag Car
1970 C20 tow rig
Old 08-01-2012, 10:27 AM   #10
OJ1988
Just a car guy
OJ1988's Avatar
Maybe not, but the truck was fine with the stock alt, replaced it witha 63 amp internal, and the AAW harness. Smoked the alternator, chenged alternator, smoked it too. Dissconnected the harness, wired the truck based on thread here and it worked fine. No other changes.
1973 Vega Drag Car
1970 C20 tow rig
Old 04-17-2016, 05:35 PM   #11
DaHos
DaHos's Avatar
Just found this out today also........
They put the "batt" terminal on the brown "tach" wire !!!!
Ugh,,,,,,,,
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 04-17-2016, 09:29 PM   #12
gmachinz
Not that it matters now, but I stock the correct GM style "brown" HEI tach connector. The off-white connector is for HEI BATT and the brown connector is the TACH lead-weird how the AAW one won't plug in-I don't know that there's a different style....unless of course they switched suppliers and are using an offshore version of a Delphi connector.....that wouldn't surprise me.
gmachinz is offline   Reply With Quote
