![]() Join Date: Sep 2011
Suburban cargo area
I didn't know that the Burbs had a wood floor under the rubber mat. I did know that the panel trucks have a wood floor. W/o pulling off the rubber mat the wood floor seems to be in good shape. I can see a small bit of the wood inside and most of it from the bottom/underside. From the bottom it all looks good. I will be checking more thoroughly tomorrow when I drop the gas tank.
If the wood is good any reason not to Rhino line over the rubber mat? I plan on Rhinoing the complete floor inside and most/all of the underside of the truck. Friend owns a Rhino franchise. Here is a pic of the floor, looks pretty good to me. ![]() Several new pics in my gallery; http://67-72chevytrucks.com/gallery/...&ppuser=103447
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Never Ending Projects
Re: Suburban cargo area
I don't think you can Rhino Line over the rubber mat. I know people have had good luck over wood but the rubber mat is too flexible and would likely allow it to peel off, if it even sticks to begin with.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#3 | |
![]() Join Date: Mar 2010
65 burb On the road Mar 26th Finally |
Rhino over the rubber mat?
I'll check with my buddy Dave, he has the Rhino franchise. They just did a bunch of work at the Nationals ballpark in DC. Just, as in just before the season opened.
No I did the underside.
Ohh, Ok.
