Old 07-10-2012, 10:03 PM   #1
Jayschevy
Water temperature gauge question
I recently purchased a 71 C10. The previous owner had the water temperater going to a seperate gauge instead of using the gauge in the instrument cluster. I decided that I wanted to use the one in the instrumnt cluster. After removing the cluster I found out that the cluster's circuit board was damaged and thats probably why the temp gauge did'nt work.
I have a new cluster on order but my question is how do I hook up the water temperature to my new instrument cluster. There doesn't seem to be a place in back of the cluster to screw the water temperature probe into.
Any help would be appreciated.
Jayschevy is offline   Reply With Quote
Old 07-10-2012, 10:40 PM   #2
SS Tim
SS Tim's Avatar
Re: Water temperature gauge question
Sounds like the PO put in a mechanical temp gauge. If you truck had the factory gauges (RPO Z53 or U16) then it was built with an electrical temp. gauge and the wiring should be there. It consists of a wire running from the cluster to an engine mounted sensor that is grounded to the engine. As it changes temp. it changes resistance that the gauge reads.
SS Tim is offline   Reply With Quote
Old 07-10-2012, 10:55 PM   #3
Jayschevy
So the one on the cluster is electrical. Where is the sensor at on the engine for the sensor on the cluster? Also, what do I do with the mechanical sensor? I can't remove it unless I put something in its place.
Old 07-10-2012, 11:05 PM   #4
oklalawnboy
oklalawnboy's Avatar
The electrical sending unit would go in place of the mechanical sensor. My 72 has 2 sensors one in each head. Drivers side toward the front and passenger side towards the rear but my gauge doesn't work either. I just haven't looked for what's wrong yet. Maybe tomorrow...... yeah right.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 07-10-2012, 11:11 PM   #5
SS Tim
SS Tim's Avatar
The PO probably pulled the electrical sender to install the mechanical line. Look around the the engine, whatever you have, and see if there is a 20ga dark green wire with a plastic connector. If you find the wire pull loose the cluster connector and resistance (ohm) check the wire. If it is good it will be very very low. Then and with a good cluster I'd worry about installing a new or known good temp sender. The factory manuals are a great help in sorting these things out. Get both the MY specific chassis and the overhaul manuals. Haynes and Chiltons are usually to generic to be helpful.
Old 07-10-2012, 11:36 PM   #6
Jayschevy
Ok, I'll look tomorrow for the green wire tomorrow. Looks like I'll have to buy an electrical sender...
