07-11-2012, 11:08 AM | #1 |
Lets talk about ELECTRIC Fans
I am told that instead of trying to find a shroud that fits in my conversion from a 6cyl to a V8 radiator and engine that I should just get an electric fan and not deal with all the hassel.
I am also told that the best fan around as far as CFM is concerned is the Taurus, Windstar or Lincoln Mark VIII fan. Although apparently they draw a huge amount of amperage. So the question is: Whats really the best choice? If I do go with an electric fan, what else do I need to consider?
http://s994.photobucket.com/albums/af62/ScottAz2/ |
07-11-2012, 11:15 AM | #2 |
Re: Lets talk about ELECTRIC Fans
You`re going to have to buy a fan big enough to pull minimum of 2500 CFM thru a fan shroud so you will need that also, you`ll need a auto temp switch to control said fan. You might look at spal fans get a 16 inch curved blades, they pull 3200 CFM.
http://www.google.com/search?client=...w=1246&bih=582
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
07-11-2012, 11:45 AM | #3 | |
I was thinking I would just wire it direct and when the truck starts the fan would be on. Good idea or bad?
07-11-2012, 12:16 PM | #4 |
The Taurus/MKVIII fans are excellent, and even though they are *gasp* ford, you can't beat OEM reliability, especially something critical like an E-fan.
You need a Coolant temp switch and a BIG Solenoid for power. 100% on all the time is not a good idea.
2010 Basalt Black Porsche Cayenne GTS - Daily driver 1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again. 1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac |
07-11-2012, 12:48 PM | #5 |
Agreed!! I put a Taurus fan on my drag car and it works awesome. $15 from the you pull it yard....
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
07-11-2012, 01:31 PM | #6 |
07-11-2012, 02:53 PM | #7 |
Mid 90's with a single fan assembly and a 3.8 litre engine. You will find a ton of them with the dual fan but I think that might be too wide, although I'm not sure.
I found one at out pull it yard but it was $35.00 Also found the bucket seat brackets I was missing from the 05 Tahoe seats for $40.00 And a set of NEW 265/65/18's for $400. Gotta love those recycle places.
07-11-2012, 02:55 PM | #8 | |
BAD: Could you elaborate a bit for me please about the temp switch and Solenoid please? I hear that I should run this on a 30 amp relay also? Is there a concern about the size/age/reliability of the old alternator? It's on a 64 283 motor.
07-11-2012, 03:40 PM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
You can get a temp switch/relay ( 30amp+) from your local auto parts store dude. Hayden makes one, make sure you put a large inline fuse on it too, like 50AMP
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-11-2012, 03:44 PM | #10 |
30 amp? The Taurus fan will laugh at that. You need a BIG relay (75 AMPS) or a solenoid. The thermal switch usually goes into a pipe threaded hole in your cooling system (I've used thermostat housings) and grounds out at a certain temp to turn the fan relay on. By the time you piece it all together, it would probably be a better deal to get one of the simple fan relay controls for around 50 bucks, then you can control the temperature that the fan kicks on.
I can't say about your particular alternator, but EFans will surely put a charging system to the test, especially that massive amp draw when they first start up. You probably will need to worry a little less than a guy running EFI and all the electronic devices that entails.
07-11-2012, 04:08 PM | #11 |
If you go with the Taurus fan and not the mark VIII fan you will be fine with a regular 30/40 amp automotive relay on single speed. Low speed on the Taurus fan draws 18-24 amps. The low speed will be all you need unless you plan on running something wild. I have a Taurus fan on my 65 and it has cooled a 500+ hp 406 in 90+ degree heat on low speed. It currently cools a 5.3 with no problems too.
07-11-2012, 04:09 PM | #12 | |
07-11-2012, 04:26 PM | #13 |
Hollister Road Co.
This will help you determine if you want a Mark VIII style.
http://www.thehollisterroadcompany.c...VIIIrelay.html http://www.thehollisterroadcompany.com/MarkVIII.html Mark VIII style is 3200- 3600 CFMon high at the most not 5K 5500 CFM. Taurus is less. Most all the Mark VIII fans I have seen ( in the hundreds) are single speed used with a variable controller. All Mark VIII fans that have a white plug connector on the motor are single speeds. They all have three wires so you can't tell by looking other than the white connector, you have to test it or just get a TBird fan. 94 4.6L TBird and Cougar fans are 18" 2 speed and look the same as a M8. You can get an TBrid/Cougar fan at rockauto.com for $68 new. You can also get a new Taurus fan there. |
07-11-2012, 05:17 PM | #14 |
I upgraded to a 94 amp altenator from a 80's truck. Runs two fans electric fuel pump and all my other accesories no problem. The stock alt would run the battery dead with a 16 inch electric fan.
07-11-2012, 05:26 PM | #15 |
Well that's all I needed to know
I'll explore the clutch fan option a little more closely then since I don't plan any other mods that would require a better alternator. |
07-11-2012, 07:08 PM | #16 |
I bought an aluminum 2 row radiator for the 60-66 C10's with Electric fan and aluminum fan shroud combo on Ebay for $289. The fan was just some generic electric fan that sells on ebay for under $20. Then I got a temperature switch for the fan with a probe that sticks between the radiator fins for 30 bucks From Summit. That in combination with a 180 thermostat and my truck hovers around 190 degrees, even when we had 2 weeks of 100+ degree temps. In fact when the fan kicks on I can see the temp drop down from the 190 degree range back to around 180 pretty fast. Not sure how many amps my alternator is, but it still uses the external regulator, so I don't think the amperage rating is too high. The fan has not caused any power problems. My truck is daily driven.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
07-11-2012, 08:08 PM | #17 |
Why not just grab the relay from the Tarus? I did that on another car and it worked great. Then you can run High or low speed.
07-11-2012, 11:01 PM | #18 | |
Would an 80's - 90's alternator bolt on to the bracket from a 64 c-10 with a 283 in it?
07-12-2012, 01:12 AM | #19 |
Here is what my Taurus fan looks like..
[IMG][/IMG]
07-13-2012, 12:51 AM | #20 |
60-66 Nut
As long as the mounting points are in the correct orientation. Typically a small or big block with V-belts should bolt up just fine. Most of the serpentine belt driven alternators I have seen are clocked wrong, but sometimes you can rotate them to where you need them. Once you have one bolted up, you then need to change the wiring.
07-13-2012, 10:13 PM | #21 |
I scrounged up a fan from the bone yard out of a 96 Cougar that had a 4.6 litre and air conditioning. Hope it's the right fan.
I am curious if one of you can tell me what these 4 wires go to? I think the big blue one is power, the big black one is ground....and I have no clue what the other 2 are supposed to do. You will notice that on the plug end they merge into only one wire. Anybody know?
07-14-2012, 07:57 PM | #22 |
I just finished putting a 93 Taurus fan in. Wired it through a 80amp constant duty solenoid, used 8ga wire and hooked to a 75amp toggle.
Its a monster of a fan. I only have low speed hooked up and I idled around a fairgrounds for hours in 85 degree temps. Never ran above 190 and I have no mechanical fan... On high, while testing it, it pulled a shop rag from 3ft away. Im sold...
Tim Road Hounds |
07-14-2012, 09:01 PM | #23 |
Seems that everybody you talk to about what size relay and switch to run has a different opinion.
I have heard anywhere from 25 amp all the way up to 75 amp. The "kit" my auto parts shop sold me was a 30 amp and it says it works on the Taurus fan, but then who knows until it works or doesn't. Anyway it is raining here now or I would take a few pictures of what I did. We need the rain so i'm not complaining.
07-14-2012, 09:56 PM | #24 |
how about this Amazon.com: Dorman 620-101 Radiator Fan Assembly:... new and complete and fits 90-95 taurus 3.8 v6
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
07-15-2012, 09:17 AM | #25 |
If you want NEW then I guess thats an okay deal.
I got mine for $35.00 and it looks new and works. Pick a Part yard.
