Old 07-11-2012, 11:54 AM   #1
CdM
CdM's Avatar
axle saddles
Where do you guys find them? Trying to get a few sets for the trailing arm style. playing the musical rear axle game on a few trucks.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 07-11-2012, 11:59 AM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: axle saddles
Try CPP, That's where I got mine for my 69.
Dunenutt is offline   Reply With Quote
Old 07-11-2012, 12:54 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: axle saddles
I usually buy mine from Early Classic: http://earlyclassic.com/catalog.aspx
Search by "rear axle saddle"
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-11-2012, 07:04 PM   #4
deuceman32
Re: axle saddles
If you are talking 60-72 coil spring 1/2 ton, then I think this kit from CPP is the way to go. It uses the stock frame mount for the new long panhard bar which connects to the RH axle saddle.
http://www.classicperform.com/Store/...k/6072DRCK.htm
deuceman32 is offline   Reply With Quote
Old 07-11-2012, 07:10 PM   #5
deuceman32
Re: axle saddles
If you really just want the saddles, those are here;
http://www.classicperform.com/Store/...ck/6072RAS.htm
Old 07-12-2012, 12:13 AM   #6
CdM
CdM's Avatar
Re: axle saddles
awesome.. thanks for the input!!
