Old 07-11-2012, 02:09 PM   #1
BIG V
stumble on 87 suburban,
Question, I have a 87 chevy suburban with the 350 and 700r4. there is a off idle stumble. i have 13 lbs of fuel pressure, the fuel filter has been swapped, I changed the plugs and wires, cap and rotor. I have removed the iac and completely cleaned the iac and the port. im stumped it does a off idle stumble acts like it has a cam in it. then it goes away the stumble only lasts for a second then goes away. Any insight would help.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 07-16-2012, 04:12 PM   #2
Jonboy
Slots go on anything!
Re: stumble on 87 suburban,
Did you check EGR?
1974 Jimmy- 5.3/4L80e/NP241
Old 07-16-2012, 07:02 PM   #3
BIG V
yes i did. It helped the problem but hasn't fixed it.
Old 07-17-2012, 06:51 PM   #4
cal30_sniper
cal30_sniper's Avatar
Ignition Module and Coil are a quite common problem for TBI injected vehicles. I'd start there, replace them with AC Delco replacements, not the aftermarket "performance" offerings from Accel, MSD, etc. They are notorious for blowing out right after being put in.
If that doesn't fix it, I'd look into replacing the MAP sensor and TPS. If you have a digital voltmeter, check that the MAP sensor and TPS are both functioning properly. Also, have you checked to see if it's throwing any codes yet?
-cal30sniper
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 07-17-2012, 07:07 PM   #5
BIG V
I have a ethos to watch live data on. The tps is working great smooth waveform , Has all ac delco ignition on it, map sensor is reading correctly also. all rubber hoses have been replaced under hood, do you think if the harmonic balancer has slipped it would cause these problems since the inital timing is set on the balancer? No codes yet but you never know.
Old 07-17-2012, 07:26 PM   #6
cal30_sniper
It is possible. The easiest way to check is to unplug the brown wire for ignition advance, and see how it runs on base timing. If it's set correctly and running really rough, that means your ignition is retarded. Every balancer I've seen slip "advanced itself" so that even when running the proper 0-6* of base ignition advance, the balancer would show something like 15-40* of advance at idle. If you try to retard it back to within spec, the engine will get really choppy, vacuum will drop, and it will die. As far as I know, that's the only way the balancer should ever slip due to the direction the engine is rotating.
-cal30sniper
