Old 07-11-2012, 03:18 PM   #1
chewychevy67
67-68 glove box door lock???
did these actually come from the factory or were they a dealer add on? Also what key would have been factory on 67-68's. the rounder oval one or the octagon key for the ign and door locks? anyone know.
chewychevy67 is offline   Reply With Quote
Old 07-11-2012, 03:27 PM   #2
AirSpeed
AirSpeed's Avatar
Re: 67-68 glove box door lock???
I ordered a new set for mine, came with matching locks for the door, glove box and ignition, they all use one key. Mine had a lock on the glove box when I got it but no key. I think it's a factory option.
AirSpeed is offline   Reply With Quote
Old 07-11-2012, 04:09 PM   #3
FirstOwner69
FirstOwner69's Avatar
My 69 CST came from the factory without a glove box lock which, if available, would have likely been part of the CST option. I don't recall ever seeing a 67-72 with a lock from the factory or, for that matter a light. Perhaps the 73 and up had locks.
The 69s came with only one key (actually 2, but they were the same) for the doors and ignition. It has rectangular head with the square Mark of Excellence GM logo as used on the choke delete plugs. I can't speak for the 67s and 68s, but I believe those were the first years for that GM logo. Otherwise, I'd think the key would have been the earlier octagonal style.
FirstOwner69 is offline   Reply With Quote
Old 07-11-2012, 05:15 PM   #4
eagleuh1
eagleuh1's Avatar
My 68 came from factory with glove box door lock that used the oval GM ignition key. The doors used a seperate squareish GM key. My aftermarket lock set uses seperate key for glovebox. Gotta keep the gun locked up seperately.
eagleuh1 is offline   Reply With Quote
Old 07-11-2012, 07:18 PM   #5
FirstOwner69
Interesting. Maybe they got cheap starting in 69. Anything on the SPID about it?
Old 07-11-2012, 07:38 PM   #6
chewychevy67
my 67 came with a octagon key for doors and ignition and didn't come with a glove box lock. i want to buy one but i have seen them come with both 67 style keys and i just wanted to know if they were coded to the octagon door key or had a seperate lock with the oval style. i think the cars had the oval style key for the trunk but not certain if trucks would have them. In 69 GM changed the styling of the keys for theft issues i believe. Rod.
Old 07-11-2012, 11:11 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
All of the '67's came from the factory with the octagon keys. They used the "A" keyway. The biggest problem with them was that they didn't stick out of the recessed ignition far enough and were hard to get a hold of. Customer complaints was part of the reason GM switched to the rectangular head ignition key. I honestly can't tell you if the glove box locks were factory or dealer added. My theory is that if they were installed at the factory they would have been keyed the same as the other locks on the truck so I think they were dealer, locksmith, or owner installed. They also would definitely have been an option so should have been listed on the option sheet.
LockDoc
Leon
Old 07-12-2012, 05:41 AM   #8
68 TT
Still plays with trucks
68 TT's Avatar
My 67 has the single octagon key and it has the locking glove box. Same key for all. Not on the SPID though. Probably a dealer installed option.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
