Old 07-11-2012, 05:07 PM   #1
dani
RWAL / Brake / Cruise Wiring Problems ?
Hello all,
Glad to find such a great site with like-minded individuals. I hope to be of help to others in the near future but unfortunately require some expertise with something that has me at a standstill (we all love these moments don't we). Any and all help would be greatly appreciated.
vehicle specs - 1990 GMC Suburban 1500 4wd SLE - 170,000 miles
(stock as far as I know - bought it used from an elderly gentleman)
I have followed several troubleshoot scenarios from the forum which have been great but include no mention of problems where I am stuck.
original problems - cruise inop and brake light on over 35 mph - code 10 (purchased vehicle this way thinking small repair -
1- tested RWAL module 6 wire harness
terminals A-C (battery voltage)
terminals A-F (no voltage - key on)
2- tested brake switch with vacuum attachment
(switch mounted towards passenger side)
pink/black stripe (battery voltage - key on - no pedal)
purple (battery voltage- key on - no pedal)
3- began chasing purple wire through harness up behind gauge cluster where
it runs into a grey plastic 6 wire box with circuit board inside - upon
inspection found board is damaged on the brake switch 12 volt side but
find no mention of it in any schematic I have found online.
pins on housing
A- purple - 12 volt comes from brake switch with vacuum attachment
B- purple/black stripe - continues in harness towards floorboard
C- purple/white stripe - continues in harness towards passenger side of dash
D- tan/white stripe - continues in harness towards floorboard
E- tan/black stripe - continues in harness towards passenger side of dash
F- tan/white stripe - feeds to instrument cluster connector
I know the board needs to be replaced but have not been able to locate a part number or how to troubleshoot the other wires attached to it so as not to damage the new one or something else.
Sorry for the long explanation - just wanted to include as much info as possible. Thank you in advance to any who choose to help out.
-Dani-
dani is offline   Reply With Quote
Old 07-12-2012, 06:19 AM   #2
tobiahr
tobiahr's Avatar
Re: RWAL / Brake / Cruise Wiring Problems ?
i would see if you can solder a jumper across the broken trace and test it
tobiahr is offline   Reply With Quote
Old 07-12-2012, 05:06 PM   #3
dani
tobiahr -
Thanks for the thought and I will definitely try that as a test once I have made sure there is not some other problem that made it fail.
I don't want to cause further damage to it or something else in the wiring without knowing what it is (part# would be ideal for proper replacement) and how it should operate (for troubleshoot purposes)
However, until such time I will just have to try and fight my way through.
Old 07-12-2012, 09:58 PM   #4
dani
Update
I had some spare time and decided to go another round with the wiring.
I will try to keep the progress updated so that others may use for reference.
pins on housing
C- purple/white stripe - runs to Torque Converter Clutch Solenoid
D- tan/white stripe - runs to Parking Brake Assembly
just chasing down wiring for now
