Old 07-11-2012, 06:06 PM   #1
1972RedNeck
1972RedNeck's Avatar
Amp Clamp
I would like to get a multimeter with an amp clamp. What brand/model would you all suggest? It needs to be rugged, durable, accurate, simple, and made in the U.S. of A.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-11-2012, 07:03 PM   #2
rcbildr
rcbildr's Avatar
Re: Amp Clamp
For the longest time I used a Sears voltmeter/amp clamp. I remember it was around $100. It held up pretty well considering it was meant for home/automotive use and I was using it for work...I'm a maintenance technician.
A while back I found out there are 4 categories of multimeters 1-4. 1 is for like bench testing and small stuff, 2 is for home/automotive use, 3 industrial maintenance, and 4 is what lineman use. The big difference I noticed between the Sears I have and the Fluke I bought for work was the saftey fuses in it. The sears had automotive fuses and the fluke had much bigger industrial type fuses in it.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 07-11-2012, 07:25 PM   #3
1972RedNeck
Re: Amp Clamp
Fluke is made in china. I refuse to buy one. Where are the sears made?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-11-2012, 09:45 PM   #4
hayhauler71
hayhauler71's Avatar
Re: Amp Clamp
Fluke is by far one of the best meters out there. I use a OTC meter at work that I bought 20 plus years ago for $450.00 and still using it today I think they are still made in Owatonna MN
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-14-2012, 12:19 AM   #5
oldspowered67C10
Re: Amp Clamp
Fluke is the way to go, the 88V is the best automotive multi meter out there. Just looked at mine, made in USA.
oldspowered67C10 is offline   Reply With Quote
Old 07-14-2012, 09:14 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Amp Clamp
I'll have to agree on the Fluke.Made in USA doesn't mean much anymore.As long as they do some of the assembly here they can claim it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-14-2012, 09:59 AM   #7
pumpkin
pumpkin's Avatar
Re: Amp Clamp
We live in a world wide economy nowdays, and with they way lawers have a way of getting around things we have no way of knowing what we are buying. I just go with the best warrantee/gaurantee. Depending on what you need the amp clamp for, I would asume automotive since your in a truck forum. If price is an issue then I don't know. I have a Snapp on amp clamp that hooks up to my Snapp On Vantage and Mmy Modis. Being a mechanic i have these as they are invaluble yo serious mechanics, but it may be too pricey for some.
pumpkin is offline   Reply With Quote
Old 07-14-2012, 06:59 PM   #8
67lowered
Re: Amp Clamp
At work, I have used fluke 87, have an add on amp clamp, most every day, for years and years, have dropped it more than a few times, keeps on working. Have a separate fluke amp clamp, reads ac and dc amps, rugged, that works good, used it about 5 years. Have a greenlee amp clamp, don't use it much, works good too, have had it about 3 years. Just bought a milwaukee multi-meter for my own, with open end amp probe, looks rugged, works good like the others, like the backlight, white numbers on black background. I like good tough accurate meters
hope that helps
67lowered is offline   Reply With Quote
