Old 07-11-2012, 07:00 PM   #1
Chief_Wiggum
TH350/NP205 Adapter Bearing
I'm swapping my NP203 for a NP205 out of a '72 Blazer. The adapter has the support bearing in it which is trashed. Anyone know the part number for it? Digging around online, I can't seem to find anything. Instead of replacing it, can I replace the drive coupler with a later straight unit and just leave out the bearing? Thanks for the info.
Mike
Chief_Wiggum is offline   Reply With Quote
Old 07-15-2012, 03:31 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: TH350/NP205 Adapter Bearing
Yes, you can delete the bearing. I tried to find that bearing and coupler one time and it is discontinued. The coupler was sloppy, so I went with the non bearing coupler and everything is a-ok.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-18-2012, 02:52 PM   #3
Chief_Wiggum
Thank you for the information. I appreciate it.
Old 07-17-2014, 02:21 AM   #4
WhiteWhale
WhiteWhale's Avatar
what years have the non bearing coupler? Part number?
WhiteWhale is offline   Reply With Quote
Old 07-17-2014, 07:23 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I think 1970/71 was the first year for the non bearing coupler.
I got mine at a place called 4xheaven in NY. Call em up.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-17-2014, 05:34 PM   #6
Orange Crate
Orange Crate's Avatar
Chief....please use search, your info was discussed here:
http://67-72chevytrucks.com/vboard/s...hlight=adapter
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 07-18-2014, 12:51 PM   #7
WhiteWhale
WhiteWhale's Avatar
I have a January built 1972 K20 which still has the bearing.
For those who wish to keep the bearing in place the part # is MRC 209S.
Here are the rest of the part numbers for the square O ring, 2 inner seals and t case to adapter seal (mandatory!! do not seal with RTV)
O ring : TK30046
Seals : 471424
T/C seal: TK10516, QU50450
Old 07-19-2014, 02:17 AM   #8
kwmech
Make sure you pack the spline coupler with grease before installing--both sides
Old 07-19-2014, 02:53 AM   #9
WhiteWhale
WhiteWhale's Avatar
Pack? I put a finger full of HD grease on each side, should I pack it full?
Also forgot to mention there is also an O ring on the T/C input shaft that slides into the end of the coupler. No part number or listing but got one at an old school auto parts that had the orange Dorman boxes and i just matched them up.
Old 07-19-2014, 09:17 PM   #10
kwmech
Well, you don't have to pack it solid, but there should be a decent amount
