Old 07-11-2012, 07:41 PM   #1
davbell22602
davbell22602's Avatar
GMC 351 V6 "M" Engine Parts
Does anybody where to get parts for these engines? I need a oil pan for 351 V6 M. Do they have the same bolt pattern as the chevy 305/350 v8 oil pan?
1990 Chevy C2500 4x2 350TBI
1997 Chevy K1500 4x4 350Vortec
davbell22602 is offline   Reply With Quote
Old 07-11-2012, 07:47 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: GMC 351 V6 "M" Engine Parts
You might ask member coyoterun.He is a lover of the V12 version of these engines whhich are just a doubled one.He may have a source he would share.Or maybe a crossover parts reference.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-11-2012, 07:52 PM   #3
davbell22602
Couldnt find that member.
Old 07-11-2012, 09:01 PM   #4
100%Chevy
The only oil pan that will fit is one from another GMC,v/6 engine.
Mike./
100%Chevy is offline   Reply With Quote
Old 07-11-2012, 09:05 PM   #5
davbell22602
Mike./
Who sells them new or used?
Old 07-11-2012, 09:08 PM   #6
MusicMan70
MusicMan70's Avatar
Craigslist, Ebay, Partsboard here...are sources
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-11-2012, 09:09 PM   #7
davbell22602
Craigslist and ebay dont anything for GMC V6.
Old 07-11-2012, 09:34 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
No oil pan... but there's quite a few parts for 305 and 351 V-6's on ebay...
http://www.ebay.com/sch/i.html?_trks...51+V6&_sacat=0
Froma little digging I did on Google... it sounds like a pan for a 305 V-6 might fit.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-14-2012, 12:22 AM   #9
oldspowered67C10
Some parts are available for these engines new but very few, we recently sourced a fuel pump for one at the local parts distributor(star auto parts) but stuff like oil pan will have to be sourced used, have to hunt around.
oldspowered67C10 is offline   Reply With Quote
Old 07-14-2012, 02:23 PM   #10
1972RedNeck
1972RedNeck's Avatar
Originally Posted by GASoline71 View Post
From a little digging I did on Google... it sounds like a pan for a 305 BIG BLOCK V-6 might fit.
The V6 has a skirted block like the Ford FE. It has no dent where it goes over the crank.
1966 F250 4X4 416
1972 K20 350 4 OTF
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-14-2012, 09:00 PM   #11
MusicMan70
MusicMan70's Avatar
I received this info below about the oil pans, from one of the very knowledgeable Guys; Lewis Matkin, from the 6066 GMC website. Parts CAN be found on Craigslist; not always in your region or by direct order, but I have purchased many parts from the CL including my 401M.
http://www.adhuntr.com/ used to be Allofcraigs
http://www.mecanicapedrosa.com/
all GMC V6 engines carry the same pan configuration. The only
difference is the depth of the pan. The 305 pickup engine has a shallow oil
pan and may not allow the oil-driven govenor spinner asm to be installed on
the pump. It is a 5-qt. pan. However, if he finds one from a
305-351-401-379-432-478 out of a 4000 series or larger truck it should work.
Most of these pans are at least 8-qt. capacity and will bolt up to any of
these engines
Best of luck with your search, I'll keep my eye out as well.
MusicMan70
1961 GMC Suburban
Old 07-14-2012, 09:56 PM   #12
davbell22602
I also need pistons and connecting rods now too. Found broken pieces of a connecting rod and piece of the piston skirt. Thanks to all the replies.
Old 07-14-2012, 10:51 PM   #13
duallyjams
duallyjams's Avatar
351M do show up on CL for sale , it sounds like it would be cheaper to find a used engine.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-15-2012, 07:56 AM   #14
davbell22602
these engines
Thanks for the 2nd link. I found pistons for the 351 V6 for $36. Emailed them to see if there still available and see if they have the connecting rods also.
Old 07-15-2012, 11:44 AM   #15
davbell22602
Can I use 305c, 351c, etc connecting rods in M series engine block. I have a 351 V6 M according to ID tag on the truck. Ill check the castings on the block this week.
Old 11-18-2012, 11:34 PM   #16
davbell22602
Does anybody if the medium duty and pickup truck 351 used the same internal parts such as pistons, connecting rods, etc?
Old 11-19-2012, 12:00 PM   #17
PanelDeland
Try cayoterun .I knew his nic was spelled funny but r when I posted before.I'm sure he's found a few things for them over the years since he's found enough to run a v12.
Old 11-20-2012, 11:16 AM   #18
BobS
BobS's Avatar
A lot of the parts are the same. If you have a 351M, it came from a medium duty truck, 351E's were installed in light trucks 66-69. The "M" and "E" engines use a different intake and heads with bigger ports for increased air flow, the 351C uses smaller ports like the 305E. "C" and "M" engines (medium duty) use pistons with 4 rings instead of 3. There are plenty of parts for these engines around, it's just a matter of finding them.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 11-20-2012, 11:35 AM   #19
mgkgmc
mgkgmc's Avatar
Here is a truck in Phoenix getting parted that has a 305 v6.
http://phoenix.craigslist.org/nph/pts/3417200421.html
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 11-20-2012, 12:30 PM   #20
davbell22602
Bob
I was told by cayoterun that they were the same as far as he knew. He said the immigration motors where different cause they used propane or natural gas. I couldnt find anything on jolleys site about a 4 ring piston.
Old 11-20-2012, 12:54 PM   #21
jbgroby
jbgroby's Avatar
Dav,
First join Jolly's 6066 Yahoo group it is dedicated to the V-6 in all its forms. Next when searching ebay punch in this search string 196* GMC anything listed for 1960-1969 GMC should pop up. The * serves as a wild card feature and will encompass and include all year items.
There is a misconception that the V-12 was just 2 v-6 welded together, nit true. Here is a link to the national club, read to your hearts content.
http://6066gmcguy.org/
Page on the V-12 engines
http://6066gmcguy.org/TwinSix.htm
Hopes this helps.
jbgroby is offline   Reply With Quote
Old 11-20-2012, 01:10 PM   #22
davbell22602
Originally Posted by jbgroby View Post
Dav,
Hopes this helps.
I already joined the yahoo group and they werent very much help and same with stovebolt since were dealing a medium duty truck. I'm having better luck on here on getting the info I need. I check out the other.
Old 11-21-2012, 07:21 AM   #23
Littletony
Littletony's Avatar
I do not know if this will help, but I just got a box of mail in. In the box I had a stack of Car Craft mag,s in the December issue there is a write up about the v12. Here is the web site maybe this guy can help find the parts you need.
ThunderV12.com
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 11-21-2012, 09:10 AM   #24
davbell22602
ThunderV12.com
Thanks But looks like all he has is V12 parts.
Old 11-21-2012, 07:33 PM   #25
Erl
Erl's Avatar
If I was you I would look for a used engine. The parts off a common 305 V6 will work on your 351. Used engines go for $50 on up to $250. They are easy to find, once you start looking. I designed the HEI upgrade on Jolley's page and would highly recommend it.
ERL
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
