Old 07-11-2012, 08:11 PM   #1
Cody63
Rivits!!!!
I guess you can tell by my heading that I'm having some trouble with the rivits on my '63. Some of them have come out with grinding the head off then using a BFH on them. Others, not so much.
I just wanted to see if anyone had a real solution to getting these things out.
I'm wanting to install a sway bar and need to get the rivits out to do so.
Thanks for your help
Cody
Cody63 is offline   Reply With Quote
Old 07-11-2012, 08:13 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Rivits!!!!
Here are some good ideas: http://67-72chevytrucks.com/vboard/s...d.php?t=291939
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-11-2012, 08:31 PM   #3
Cody63
Re: Rivits!!!!
Thanks for the reply.
I've tried the grinding and punch method but, some of these things are really stuck in there. Is that just what to expect?
Old 07-11-2012, 08:50 PM   #4
Budman56
Budman56's Avatar
Re: Rivits!!!!
Cody
Cody what I have learned with trucks rivets is that you need to make sure that you have ground the head off so that you can see the hole / ring then sometimes you will have to great it up them beat it out with a center punch. that's it there is really no easy way to do it.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 07-11-2012, 11:01 PM   #5
hd74
Re: Rivits!!!!
some times you nhave to say some bad words,sometimes not
hd74 is offline   Reply With Quote
Old 07-11-2012, 11:04 PM   #6
DURG
DURG's Avatar
Re: Rivits!!!!
Easy way I did it. Step drill, take the head of with a flat chisel and then punch them out.
DURG is offline   Reply With Quote
Old 07-11-2012, 11:30 PM   #7
tincan1966
tincan1966's Avatar
Re: Rivits!!!!
Have also found that sometimes, the parts are in a bit of a bind, so clamp the parts tight, then drill /grind, or chisel the head off, and punch out. Just a little bit of twist and cause the rivets to bind up.
tincan1966 is offline   Reply With Quote
Old 07-12-2012, 12:55 AM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Rivits!!!!
I found once I bought a high quality air chisel/hammer (mine is a Snap-On) the rivets come out much easier.
I used to X pattern cut the head and the air chisel them off but I ran into areas where I couldn't cut a X pattern, hence buying the new Snap-On one.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-12-2012, 01:06 AM   #9
sandiego65
sandiego65's Avatar
Re: Rivits!!!!
I have to agree with mike making a x with a angle grinder knocking the head pieces off a quarter or half at a time with a flat chisel then knocking them out with a punch. A small sledge helps and so does some huevos haha good luck.
sandiego65 is offline   Reply With Quote
Old 07-12-2012, 08:24 AM   #10
1963c-10
1963c-10's Avatar
Re: Rivits!!!!
I had to use the drill and chisel method on bumper carriage bolts also. I have seen a few 1st gen c-10's that had castle nut style nuts on the bumper bolts which fill w/dirt and have destroyed the nuts over the years.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-12-2012, 10:02 AM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Rivits!!!!
The EASIEST way I've found is to use a cut off wheel .... cut a slot down the middle ....
Then, all it take is a slight taop with an air chisel to slice them out.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-12-2012, 11:28 AM   #12
McCoyAZ
McCoyAZ's Avatar
Re: Rivits!!!!
I drill them out and then use the BFH and a punch to push them out.
Use 3 sizes of bit, small pilot hole,
one about 1/2 the size of the rivet
and the last one the same size as the rivet. Not the head of the rivet but the actual rivet diameter.
McCoyAZ is offline   Reply With Quote
Old 07-12-2012, 12:08 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Rivits!!!!
If you have a spot weld drill it will do a rivet head, but I also like using the punch on an air hammer if its a thick enough piece.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-12-2012, 12:13 PM   #14
Shooters_7
Re: Rivits!!!!
Grind off the head and the "BFH" technique to get them out. On some of the more stubborn ones I had to drill and then punch. Just keep at it and don't give up! Some times you need to walk away for thirty minutes and then come back to it.
Shooters_7 is offline   Reply With Quote
Old 07-13-2012, 05:03 PM   #15
maxwoof
Re: Rivits!!!!
I had good results with an air chisel/hammer. Used a chisel bit to pop the heads off and a punch bit to push them through.
maxwoof is offline   Reply With Quote
Old 07-13-2012, 06:01 PM   #16
Dustin07
Stirrer of the Pot
Re: Rivits!!!!
haha that applies to everything on a truck with 52 years of rust on it!
Dustin07 is offline   Reply With Quote
Old 07-13-2012, 06:40 PM   #17
Shooters_7
Re: Rivits!!!!
you ain't lying!
Old 07-15-2012, 03:16 AM   #18
beefshreadder116
beefshreadder116's Avatar
Re: Rivits!!!!
i like to use the plasma cutter i cut the head off then blow a hole though the rivet u could probably do the same with the torch and more finess. using heat to blow a hole throught the center shrinks the rivet and lossens all the rust.
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
Old 07-15-2012, 09:10 AM   #19
rossboss
rossboss's Avatar
Re: Rivits!!!!
Remove the head of the rivet as suggested, then heat the area around the rivet with a torch to expand the metal. With a hammer and punch it should pop right out.
rossboss is offline   Reply With Quote
Old 07-15-2012, 10:33 AM   #20
Cody63
Re: Rivits!!!!
I guess the rivets I'm having the most trouble with is the ones that have 2 pieces of metal around them. The areas with single metal have been ok.
Old 08-13-2012, 01:58 PM   #21
txinliner
txinliner's Avatar
Re: Rivits!!!!
Cody
wow cody yea ive done quite a few suspension upper ball joints you name it,the best way ive found is to first grind a flat spot on the rivet then drill a small hole and hit with an air chissel. good luck
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 08-13-2012, 02:04 PM   #22
ky-donzi
Re: Rivits!!!!
Scarf the head off with a scarfing torch tip then use a air chisel. In most cases 2-4 min ordeal per rivet.
ky-donzi is offline   Reply With Quote
Old 08-13-2012, 02:10 PM   #23
theastronaut
theastronaut's Avatar
Re: Rivits!!!!
Grind the head off and drill the rivet to nearly the same diameter as the rivet body. But DON'T go quite all the way through! Then put use a punch and hammer to knock it out. This stretches the rivet, which shrinks the diameter of the rivet body and makes it pop out easier. Just trying to knock it out with a punch will actually "peen" the rivet material outward, causing it to swell and make it tighter in the frame.
theastronaut is offline   Reply With Quote
Old 08-13-2012, 03:48 PM   #24
64fleetside
Re: Rivits!!!!
Smoke wrench is the best thing to use.
64fleetside is offline   Reply With Quote
Old 08-14-2012, 12:55 AM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Rivits!!!!
how do you smoke a wrench?
which end are you supposed to light
