Old 07-11-2012, 08:53 PM   #1
kcfirstbuild
Throttle return spring question.
I have a 307 with a two barrel rochester. I just hooked up the accelerator linkage. I forgot where the throttle return spring hooks to. I saw on here it hooked to the ignition coil bracket. Does any one have pictures of this? How long of a spring should i get also ?
kcfirstbuild is offline   Reply With Quote
Old 07-12-2012, 08:43 PM   #2
kcfirstbuild
Re: Throttle return spring question.
anyone have any advice ?
Old 07-12-2012, 09:43 PM   #3
pat 70/71
pat 70/71's Avatar
You can put the spring any where you want as long as it has tension. If you need to you can get a light duty spring at just about any auto parts store. They should stock what you need any length you want. Good luck and have fun! Cheers, Pat
pat 70/71 is offline   Reply With Quote
