Old 07-12-2012, 10:02 AM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
brand new starter making noise
so i put on a brand new starter less than a week ago and yesterday when i was out and about and stopped to do some shopping.when i came out to start the truck and it make some really bad noises. like grinding noises. any ideas i heading out for the weekend to go camping and dont want to be stranded.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 07-12-2012, 11:46 AM   #2
Shane22696
Shane22696's Avatar
Re: brand new starter making noise
Did you use any shims when you installed the new one?
80 K10 350 4 spd
4 Inch lift, 33 inch BFG M/t
Shane22696 is offline   Reply With Quote
Old 07-12-2012, 12:21 PM   #3
bowtiemanchevyman
bowtiemanchevyman's Avatar
pull off the inspection plate and look at the teeth, if they are grinding after a week of using it. the starter might of gone bad. ive had them go bad after a day. the one on my truck now has lasted 8yrs, with headers. so its a hit and miss some times.
bowtiemanchevyman is offline   Reply With Quote
Old 07-12-2012, 08:52 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
no i didnt put shims in as it was meshing fine. now its crazy its bad :S
Old 07-12-2012, 11:39 PM   #5
tucsonjwt
Mechanics I have talked to over the years have never used shims. I am not saying they are not necessary, but if they are installed without shims and work OK, I don't see why they would go bad all of a sudden. If you have the $$$ your might check out a GM high torque mini starter. They spin up faster but the downside is if your vehicle does not start on the first attempt you have to let the starter slow down for a few seconds before attempting to restart or you will grind the teeth.
tucsonjwt is offline   Reply With Quote
Old 07-13-2012, 01:19 AM   #6
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I learned early on to always rebuild your original starter. If it worked 100% when it left the factory, it will function the same after a rebuild, without the hassle/worry about shims.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
