Old 07-12-2012, 12:55 PM   #1
Katrina/10
Katrina/10's Avatar
Does a 71 have a seat adjuster return spring?
My seat does not have one, I don't know if I lost it or it never had one. If so, does anyone have a picture of it or where it connects?
Thanks,
Gary
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-12-2012, 11:16 PM   #2
pat 70/71
pat 70/71's Avatar
Re: Does a 71 have a seat adjuster return spring?
They all had a spring on the seat lever. From the handle to the actual seat base if you look real close you will see the hole it goes through. Cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 07-13-2012, 01:13 PM   #3
Katrina/10
Katrina/10's Avatar
Originally Posted by saa View Post
Mine does and it's the original seat. I'll try to get a picture for you tonight.
saa.
Here is the picture:
Hope this helps.
saa.
Well, now it looks like I need 2 springs! I did some research and believe there was also a spring on the inside of the track that helped retract the seat, now I see there is also a spring to tension the adjuster handle. I have neither one, so now the search is on.
Thanks for the info!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
