What do you use for transmission lines?
Trying to figure out what to use for my trans lines. Are you guys using rubber or metal, and how/where did you run it? Pics would be good.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
C/10 junkie
Re: What do you use for transmission lines?
X2
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
I used braided stainless steel hose. I'm running a 4L60E. I had to get some adapters. IIRC the tranny has pipe threads, and I used AN fittings to run up to my aftermarket cooler.
5/16's metal hardline. and a small peice of rubber near the cooler to allow for engine movement. NHRA rules are no more than a foot of rubber hose so use less than that on each line. Use a bender, harbor freight has a cheap but pretty good one and it will come out looking nice and solid.
I used braided lines with anm fittings for the tranny as well as all my fuel lines.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Russell pro classic hose and fittings also adapters -6 a lines
Posted via Mobile Device |
Got big-block?
![]() Join Date: Jul 2000
rubber trans cooler line all the way from cooler to tranny
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
Cruzin
all metal from trans to radiator, ran just like factory up the inner frame.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
![]() Join Date: Feb 2008
Ran hard line from trans between motor mount brace & crossmember & ended that after fuel pump. Then bent hard lines similar to factory out & down radiator with sharper bend at bottom to meet up with the other section. Used couplers to put lines together in the space between radiator & motor - easy access from underside. This allowed the rear section minimal bends after the ~45deg to get around the rear of motor. Also made sharper 90deg at radiator & down low easier. Truck was totally assembled & on the ground so the joint made it all easier to manage.
I just wanted to avoid any rubber cuz it seems like even the black tranny line stuff gets pretty soft after a few years.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
i like doing the braided line on fuel and tranny lines....partly because of my lack of skill bending hard lines,plus i think they look cool!
#11 | |
Still plays with trucks
My Camaro did that to me on the trip home from buying it. Left me stranded 20 miles from anywhere in the middle of the Mojave Desert.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Newbee
Braided stainless.
