Not too old to learn
What is correct size of fusible link ?
I'm at the final wiring check on my rebuild and find
the fusible link at positive side of battery is gone. The schematic doesn't show the size to use. The parts store has two, one is 14 gauge and the other is 16 gauge. My truck is a 68.
1968 C10 a way to long restoration. |
Member
Re: What is correct size of fusible link ?
Man I'm not sure which size it was, but maybe this pic will help. I matched it to my original when i made it. I bought a link of it from Bennett Auto i think, put some connectors and heat shrink on it, put a twist in it and good to go. Don't have truck books with me....
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
As I understand the function of the link, it is a master fuse for
the whole electrical system , not including the starter. Don't know the engineering behind a piece of wire melting down as opposed to a replaceable buss type fuse so must have an amp rating I guess. ![]()
Look through Mark's website at www.madelectrical.com You may find the answer there, he has some tutorials you can look through. He has great products and knows his stuff also. I don't work for him or anything, he and his website have helped out Chevy folks for years.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
#5 | |
I booked marked his site, and when added my computer said I already had it bookmarked. ![]() Thanks for the reminder. There is a section showing a 14 gauge fusible link for Chevys
![]() Join Date: Feb 2002
I checked under my hood: I have a 10" brown 14 gauge wire coming off a bolt on the Positive terminal -- splicing into a 10" red 12 gauge line going to the fender terminal.
I got the fusible link wire from the "Help" section at the local auto parts store. Reason for the extra length is I like having the Positive Terminal inboard and the Negative Terminal outboard.
I understand that the rule is the fusible link should be 2 gauges/sizes smaller that the wire it is attaching to.
#8 | |
the package. So 16 gauge is the one needed. The main wire attached is 12.
