07-12-2012, 07:58 PM | #1 |
Pre-bent exhaust system - any options?
For my '70 402 Longhorn restoration one non-stock alteration I'm going to indulge is either an aluminized or stainless exhaust system, ideally mandrel-bent.
I'd like to run Dynomax mufflers because I have a set on my other project and like the sound (quiet at idle and drone-free), so optimally I'd find a pre-bent pipe set and either discard the indluded mufflers or get a system without mufflers. The only complete system I've found is one from LMC, but its not for the longhorn so would wind up too short for my truck anyway. I could just haul it to a muffler shop, but I'd like smooth mandrel bends and don't know of any shops that can do that. Does anyone know of a pre-bent kit? Failing all of that, I could buy pipe and J and U bends and weld it up myself (I'm a novice, but can handle that much). If you've had any experience with a "make it yourself" kit that would fit our trucks, please let me know that as well! - Dave
07-12-2012, 10:21 PM | #2 |
Re: Pre-bent exhaust system - any options?
I used a 2-1/2" stainless pypes kit on my 68 and a 2-1/4" aluminized hooker system on my 69. Both of mine are shortbeds, but you could get some extra straight pieces and weld in.
There are a few shops around the Seattle area that can do mandrel bending, but it will cost you more than a pre made kit. |
07-12-2012, 11:10 PM | #3 |
I bought one from Lmc and it was a terrible fit( hung way to low!)My advise would be to save up a couple bucks and let A pro take care of it for you. Cheers, Pat
Posted via Mobile Device |
07-12-2012, 11:21 PM | #4 |
Don't know if this will help but here are some threads
Re: Pre-fab exhaust systems http://67-72chevytrucks.com/vboard/s...d.php?t=376291 Re: Exhaust pipes??? http://67-72chevytrucks.com/vboard/s...d.php?t=409913 Re: Pre bent exhaust for our trucks? http://67-72chevytrucks.com/vboard/s...d.php?t=257046
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-13-2012, 08:54 AM | #5 |
Still Learning
I used the cut and build yourself kit http://www.ebay.com/itm/390246153621...84.m1423.l2649
With THESE mufflers. You can see the details of it HERE. I will probably end up going back and running the pipes all the way to rear of the truck. I dumped them in front of the axle because it was so tight around my adjustable panhard bar. Good luck. |
07-13-2012, 11:46 AM | #6 |
LET'S GO RACIN'
I used a Flowmaster kit. It was a Flowmaster u-fit dual kit. Bought it through Jegs. You can get it in stainless. They have 2.25, 2.5 and 3 in. pipe. You will have to do some cutting and fitting, but i liked it alot. You can buy some 4 ft. length pipe to fill in if need be, as i did. I used up most of the system on my longbed. Just need a good sawzall. I also welded mine up, had some stainless wire laying around. Hope that helps.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM |
07-13-2012, 11:50 AM | #7 |
Newbee
I bought the Hooker kit from Summit. It had everything needed, except a couple of 90's. I put the mufflers close to the bed, above the trailing arms.
07-13-2012, 12:33 PM | #8 |
X2 on the Flowmaster kit, cheap too! I had enough left over to almost do another truck.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
07-13-2012, 12:47 PM | #9 |
I have the Magnaflow kit on my 68, it sounds wicked too. It hangs a little low but I might have a fix for that too. (move the location of the X pipe)
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
