07-12-2012, 10:03 PM | #1 |
C35 Crew Dually
at whits end
im at whits end with this starter installed it no shims like my last starter worked awsome 4 days later starter has slight grind :S so i get a shim kit install 2 shims as per my old boss (great mechanic) tryed starting it started with a slight grind. turned it off started it again huge grind. > so i try three shims starts awsome tred a few more times starts awsome then last try GRIND! what am i doing wrong?
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
07-12-2012, 10:52 PM | #2 |
Re: at whits end
I fought this same thing on a blazer. Went through countless shims and starters. I read in a book that with the starter engaged you should be able to bend a paper clip wire and have it fit snug between the teeth of the starter and flywheel. I tried it with no luck. I changed the flywheel and haven't had a problem since.
i do my burn outs in 4wd |
07-12-2012, 11:04 PM | #3 |
Re: at whits end
I would check that flywheel....
The only time that I have every had a new or rebuilt starter start grinding that soon; the flywheel had issues.
1984 C20, 454, 4 speed named "Gold Member" |
07-12-2012, 11:25 PM | #4 |
C35 Crew Dually
Re: at whits end
what do i look for? because i have looked at the teeth and they appear to be fine. do they just go?
07-12-2012, 11:39 PM | #5 |
Re: at whits end
Do you have the front support from the starter to the block on there?
Posted via Mobile Device |
07-12-2012, 11:46 PM | #6 |
C35 Crew Dually
Re: at whits end
my truck never had that
07-13-2012, 06:58 AM | #7 |
Re: at whits end
Someone left it off at one point you would ne surprised at how much it helps and keeps the starter from flexing
07-13-2012, 07:16 AM | #8 |
Re: at whits end
You might need to shim only the outside bolt. That will tilt the starter in and get the teeth closer to the flywheel.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
07-13-2012, 04:54 PM | #9 |
C35 Crew Dually
Re: at whits end
bought and installed a high tourqe start no issues so far.
07-15-2012, 01:25 PM | #10 |
Re: at whits end
