![]() Join Date: Sep 2011
Air/Heater control
I've learned here that a 3 lever control was for the deluxe heater. My 63 Burb has a 4 lever plate. What was the 4th lever for?
Mine; ![]()
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Air/Heater control
The '60-'63's with the deluxe heater had 4 levers. The '64-'66's only had 3 levers. If I remember correctly the 4th lever on the '60-'63's is for the shutoff valve for the coolant flow.
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
I'm going to install a Vintage Air ac/heat unit and the replacement panel has 3 levers. I sure didn't have an idea what the 4th was for. Thanks guys
well thanks ..now i know what mine is too .lol.. mikeS what are you going to do with the 4 lever?
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
Nothing, the Vintage Air for 60-63 only has 3 levers and fits where the OEM 4 lever goes. On my truck there are 4 slots but I believe only 2 have levers. I've seen this on other trucks from this vintage.
ETA, I reread your post. What am I going to do with the OEM 4 lever switch? Put it up for sale here.
#7 | |
