![]() Join Date: May 2005
Lock cylinder removal (without key)??
Hey all,
Is there a way to remove the lock cylinder in the ignition without the key? I know how to remove it with the key, but do I need a locksmith to do it without the key? Thanks |
Roadtrip!
![]() Join Date: Feb 2003
Re: Lock cylinder removal (without key)??
Take a sawzall from behind and cut it off.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Rottenwood Garage Member
1/4" drillbit into the lock from the front - its worked for me a few times.
I would have to agree with the other fellas. Get a new or used switch with a key and drill out the old one. I'd probably start with a 3/8 bit.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
Thanks guys. I sent out the VIN to GM's vintage division. Might be able to get the key code from them, we'll see. If not we'll drill the lock and replace it with a new barrel.
My brother got one out of a '67 for me using a couple small pics and a straight pin; I couldn't have sat there that long!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#7 | |
The Older Generation
Truck is too old to do that. The first thing I would do is to pull the passengers door lock out and see if there is a code number stamped into it. If there is take it to a locksmith and have him cut you a key. If the locks are all original the key will fit the ignition. If you don't have a locksmith close PM me the code number and I will cut you a key and send it to you for 8 bucks. If there is no code number on it, the door lock can still be disassembled and de-coded to cut a key. The destructive methods would be a last resort for me. Picture shows the location of the code number. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-09-2016 at 09:51 AM. |
LockDoc knows all.....Leon is wise!
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#9 | |
He got really lucky then. The GM sidebar lock cylinders (used from 1935 to present) are almost impossible to pick, even by very experienced locksmiths. I have been a locksmith since 1977 specializing in automobiles and motorcycles and I can count on one hand the number of GM sidebar locks I have been able to pick, unless they are totally worn out.... LockDoc
Ditto on what LockDoc said. Did exactly that with a GTO which I bought several years back.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
I built it
or to get the assembly out (of truck), i have had to pop the chrome cover off before. its just crimped on around the edge. thats all that holds the bezel to the key cylinder.. after that gets poped off its all easy to disasemble, cept the lock cylinder is still in it.. but easyer to work on
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
#12 | |
I have done that too but it depends on the lock cylinder it has in it. For some reason the diameter of the face of the cylinder is larger on some of them and that doesn't work. LockDoc
#13 |
I have the same issue with my truck Lockdoc, but I don't have the door locks that came out of it. Is there a number on the ignition cylinder itself?
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
#14 |
wanna be 67
Even if the passenger side has no code. Take it to a locksmith. I just had this issue. I had four new keys made. $21. Great deal without stress or damage. That is if it is keyed alike.
Posted via Mobile Device |
#15 | |
Yes, most of them have a code number on them. Problem is if you don't have a key it is almost impossible to get them out without destroying them. LockDoc
#16 |
I figured instead of starting a new thread I'd add post in this one. How do you remove the lock cylinder if you have the key? I just bought a new ignition and lock cylinder and put them together prematurely only to find out you have to put it in the dash and lock it down before you put the lock cylinder in.
#17 | |
67-72chevytrucks.com/vboard/showthread.php?t=476080
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() Last edited by GRX; 07-27-2012 at 07:38 PM. Reason: my spelling sux! |
#18 | |
See post #4 in this thread... http://67-72chevytrucks.com/vboard/s....php?p=4533102. The one above is actually how to install one... ![]() LockDoc
