Old 07-13-2012, 09:45 AM   #1
ymerej71
ymerej71's Avatar
Headlight / taillight issues
Hey everybody... I'm needing some help on where to start narrowing down my problem. Just recently all of my lights, headlights / tail (running) lights quit working. I pull the light switch I inside the truck... and nothing. I still have blinkers, and brake lights though. Just hoping someone can point in the right direction and save me some time once I get a chance to look into it. Thanks in advance for the help!
ymerej71 is offline   Reply With Quote
Old 07-13-2012, 09:58 AM   #2
frog210
Re: Headlight / taillight issues
Change both of your switches
the dimmer switch
and the high beam low beam switch
i had the same problem
it was my high beam low beam switch on bottom
frog210 is offline   Reply With Quote
Old 07-13-2012, 11:03 AM   #3
bowtiemanchevyman
bowtiemanchevyman's Avatar
have you check your fuse and see if you are getting power to your switch frist befor spending any money. dont throw parts at it. start first with the fuse then the power going in to the switch. it could just be a blown fuse or a lose connention too.
bowtiemanchevyman is offline   Reply With Quote
Old 07-13-2012, 11:58 AM   #4
ymerej71
ymerej71's Avatar
Thanks for the input guys... I will start at the fuse, just hadn't had a chance to crawl under the dash yet. This truck isn't a daily driver so it just hasn't been top priority. Hopefully I'll have some time in the morning to look into it... while its still cool outside!
