66 GMC 1500 2 wheel drive
i'm restoring my 66 GMC 1/2 ton 2 wheel drive & i cant find a set of u-bolts for it . it has a Dana 44 with leafs & all the catalogs i have show coils or u-bolts for a 4x4s. has any one ran across this before & if so what did you do. the ones on it were really bad. this was a farm truck & spent its whole life on a potato farm & was solid mud. i will post some pictures when i figure out how to. thanks for any help.
Re: 66 GMC 1500 2 wheel drive
you need to get them made at a spring shop. they are the ones to go to. whatever size that you need
ron |
Early Classic carries them. They are very helpfull if you give them a call and tell them what you'r looking for....
http://www.earlyclassic.com/home.aspx |
![]() Join Date: Sep 2009
ECE is where i got mine. not cheap but good product and come with nuts and washers. the guy's on the tech line are vey helpful.
X2 here. Out here we have Bett's Spring. They made mine in 20 minutes while I waited. I know that they are not some "Pacific Rim" made stuff too. Came with all the hardware and torquing instructions and if memory serves, only 50-60 bucks. Look for your local medium - heavy truck supply and they should be able to set you up.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
thanks guys for all the help im getting ready to install the rear springs & will be needing them . i will post some photos when im done.
#7 | |
I had to have mine made they were only about 8.00 each so not to bad a lil paint and htey looked great.
65 GMC 1500 lwb (in progress) |
Nice looking work by the way...post more pics as progress gets done. Be nice to follow the build.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#10 | |
they are in Flint just look in your local yellow pages. I know that it is difficult, but sometimes you just have to do it ron |
they are a mile from my home & i used them to dearch my springs last month & it took them over 4 weeks to compleat the job. to add insult to injury they misplaced my springs. i would love to keep my money in community but in this case i think i will go with a another vender. thank you though for all your help & time this is a awsome site & im so glad i found it.
#12 | |
ron |
