Old 07-13-2012, 06:26 PM   #1
82chevdiesel
Fuel tank removal
How do you remove the fuel tank on an 82 1 ton? Can It be done without pulling the bed off?
82chevdiesel is offline   Reply With Quote
Old 07-13-2012, 08:49 PM   #2
tucsonjwt
Re: Fuel tank removal
I assume it is like a 3/4 or 1/2 ton. I use concrete blocks and 2 x 4s to prop up the tank. Of course, burn up as much gas as you can to get the tank empty. Remove the bolts holding the straps, lower the rearward end first by removing a couple of 2 x 4s back there, reach up and remove the wires to the sending unit, remove 2 x 4s from the front, now you can see what you have, remove more 2 x 4s and/or concrete blocks until you have it on the floor. Installation is the reverse of removal. Not a hard job - just a dirty one.
tucsonjwt is offline   Reply With Quote
Old 07-13-2012, 08:53 PM   #3
Goldfinger
Goldfinger's Avatar
I had an issue dropping my tank because the strapped bolted on in a fashion that i could not get to them from the bottom of it. we had to remove the bed.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 07-13-2012, 10:27 PM   #4
cjlinkster
cjlinkster's Avatar
Pull the bed ( actually you just need to jack it up about 6 inches). Trust me on this one. Check my earlier posts from a few months ago.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 07-13-2012, 10:30 PM   #5
6772fan
Active Member
6772fan's Avatar
Another vote for pulling the bed. Once it's lifted, it makes the job much easier.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
