Old 07-13-2012, 07:28 PM   #1
rmahaffey
Angry 69 gmc sputters and dies when hot
First off i am not a mechanic but am fairly handy. anyway i bought a 69 gmc as a project and have been slowly working on it. previous owner was a mechanic who said engine was rebuilt and running great (now highly doubting that) finally ready to drive and when i get on the road it runs great till it gets hot then starts to sputter almost like it is not getting gas and will eventually die. if i pull over and let sit after about 5 to 10 min it will restart and drive until too hot and does it again. i have now replaced the fuel filter, distributor, fuel lines from carb (real close to block thought it was vapor lock) just ran again today and still doing it! help i am about to scap it and do something else!
Rob
(frustrated novice)
rmahaffey is offline   Reply With Quote
Old 07-13-2012, 07:39 PM   #2
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Re: 69 gmc sputters and dies when hot
Where is your fuel filter, before the pump or after?
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 07-13-2012, 07:43 PM   #3
rmahaffey
after. had someone tell me it could be the starter selinoid but tired of spending money to just find out it is wrong.
Old 07-13-2012, 07:50 PM   #4
So.Cal.Super
It'll Buff Out!
There's a similar thread right now about the same problem, do you get the whoosh if you pull the gas cap off after it dies?
Man Card Rules
Old 07-13-2012, 08:00 PM   #5
rmahaffey
ya i saw that but no. have driven with cap on and off with same result. my truck also has same carb but has the spacers so i know its not that.
Old 07-13-2012, 08:38 PM   #6
rmahaffey
fyi has all new plugs and wires. dont know enough to do a full tune up. is it time to hire a mechanic?
Old 07-13-2012, 08:41 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Since you live in a scorching climate, this may be your problem: http://67-72chevytrucks.com/vboard/s...d.php?t=516736
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-16-2012, 07:49 PM   #8
rmahaffey
ok read your link and going to put a phenolic spacer on it. It is for a 4 barrel edelbrock so the question is 1" or 2" and what is the difference.
Old 07-16-2012, 11:00 PM   #9
doubleb's69
doubleb's69's Avatar
Mine had the same problem. I put on an aluminum intake and rerouted the fuel line away from the upper radiator hose and have since not had a problem. I also used intake gaskets with cross over block offs built in to reduce heat to the intake. I did not use a phenolic spacer but I also have a Holley so it may react different.
IMO I would think a 1" would be fine. The taller they are the more of a tunnel ram effect they give but it doesn't benefit a mild engine.
Don't give up on it. It is how one learns to do things.
Post some pics of your truck.
Bud
doubleb's69 is offline   Reply With Quote
