Formerly yellow72custom
Pushrod guideplates question
My new heads are machined for 3/8" screw in studs, so i orded a set of screw in studs, and a set of guideplates from Summit last week. They were backordered on the standard flat 5/16" guideplates, so i ordered a set of "raised" 5/16" guideplates for $1 more. They arrived today, and i can't figure out which way to mount the guideplates. They will fit either way with the stepped in pointing down towards the head, or rising up towards the valve cover. I am using stock rockers and a set of Comp Magnum pushrods for my valvetrain, and the cam is a hydrualic RV grind with 204/214 duration, and .420/.443 valve lift.
Thanks for any help.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
ttt
Mike
Call summit and ask.Ask for a tech,not just the phone order taker.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
