07-14-2012, 03:28 PM | #1 |
AmsOil
Well Ive been talking to a buddy who is a Amsoil Dealer and he has been trying to get me to run Amsoil in my 86 350 GMC for years, ive been running synthetic blend for a while and am going to pull the heads off the motor and get them re built when i put them back on i was going to put some Amsoil in it...My Question is would running the stuff in a older engine like that hurt it? it reads 141,000 but i know the motor has been rebuilt before, im just not sure when......i was thinking about going with the 10W-30 Signature Series 100% Synthetic Motor Oil along with a Amsoil EAO24 25,000 Mile Filter....would it really be worth my bucks to go with this or should i try something else? Thanks
07-14-2012, 03:51 PM | #2 |
Re: AmsOil
On hyd flat tappet you need high zinc. Signature series oils dont have enough. Use Amsoil's Z-rod oil.
07-14-2012, 05:25 PM | #3 |
Re: AmsOil
07-14-2012, 09:22 PM | #4 |
Re: AmsOil
not sure about the engine but thats what I run in my nv4500 and transfer case. good stuff.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-15-2012, 11:56 AM | #5 |
Re: AmsOil
But does a stock engine with stock valve springs really need all that zddp?
07-15-2012, 12:24 PM | #6 |
Drag Racer
Re: AmsOil
id be worried on an older engine a full synthetic MAY end up showing oil leaks.
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
07-20-2012, 07:53 PM | #7 |
Extended cab fanatic
Re: AmsOil
Ive run Amsoil synthetic in many of my older vehicles and never noticed any difference. I never understood how synthetic could make and engine leak oil, but I want to point out I dont know eveything. Id love to know how it does, if it does. My older vehicles arent daily drivers tho.
My 08 Silverado has over 200k on it and doesnt use any oil between oil changes. ( about 8k between) Ive run it in it since it had 25k on it.
If it has a motor, it has my attention. |
07-21-2012, 01:23 AM | #8 | |
Re: AmsOil
There are several studies out on the internet that offer varying opinions on the zddp contents of oil. However, most are in consensus that the newer formulations of oil do not have adequate levels of zinc for engines with flat tappet cams. The zinc content can help roller cam engines as well, but it is still debated as to how effective it is in these more efficient engines. I run the 10w-40 with zinc in my 1989 tbi 454. Since I have bought a third vehicle and will not be driving it as much, I am going to switch out the oil to the Z-Rod. Either way, you cant go wrong with either one of them. |
07-21-2012, 08:06 PM | #9 | ||
"I ain't nobody, dork."
Re: AmsOil
The zddp oils aren't made to be run in vehicles with a catalytic converter from what i've read.
Also... if you're pullin' heads on an old engine to have them "redone"... you're gonna start suckin' oil past the worn out rings in the bottom end... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-21-2012, 09:31 PM | #10 |
Fabricate till you "puke"
Re: AmsOil
If that old motor has 50-80,000 on it, in good shape....I would not be scared about a regrind....if you talk 100-150,000,you are putting a "bandaid" on an f...ing bullet wound crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-22-2012, 10:21 AM | #11 |
Re: AmsOil
07-22-2012, 10:42 AM | #12 |
Re: AmsOil
Synthetic oil does not leak more easily.It will however clean all the gunk out of older engines thats packed behind the seals and making them seal. Once all the trash is cleaned out the old,worn or hard seals will begin to leak. Its really not an oil issue. Its a dirty engine issue.Synthetic oil cleans an engine a ton better than regular oil. Before all the zddp problems I always ran amsoil or royal purple in flat tappet engines with 0 issues. If the engine is actually in good shape I would just use synthetic and be done with it. If the bottom end isnt in good shape now I wouldnt bother running synthetic oil. I honestly wouldnt pull the heads and have them rebuilt on an engine with unknown miles and history. Your just asking for issues putting nice tight fresh sealed heads on a worn bottom end. I would keep saving the pennies and just rebuild the entire engine and start fresh. That way you know exactly what you have and the kind of shape its in. There will be no worries for many years.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-22-2012, 04:02 PM | #13 | |
Re: AmsOil
I hate those guys, like vacuum cleaners salesmen all they know is the hard press sale as they rattle off their pre printed speech. couple times a year I get one of them buggin me at the gas pump, like a pan handler wanting change. both are just pyramid sales as down the line everyone makes money off what you sold on the bottom of the heap. Will not ever trust any product sold in that fashion. And back to the pushy stuff, we have to boot them scamsoil guys out of our motorcycle forum all the time as its the same deal, hard press spam as the guy on the bottom is barley making a buck while all those above feed off his sales. put the crap in a bottle and sell it in a store. Pryamid sales only works for those on top. |
