07-14-2012, 07:07 PM | #1 |
Stirrer of the Pot
DM install question - cost/labor
how long does it take to install a porterbuilt front dm on a 63+ frame approx? I have a '68 and I know mechanically I'm capable of doing it myself, I just don't know if I really have the time (school/work) and am considering supplying the parts to someone to do the front install for me. I already have a lot of the basics, compressors, bags, fittings, etc from previous projects.
07-14-2012, 08:08 PM | #2 |
Re: DM install question - cost/labor
The actual x-member & related components can be swapped in a long afternoon if the drivetrain is already out of the way. The R&P notches that are used (except for the mild DM) will still need to be welded in but the rest is pretty much a direct swap (some holes need to be enlarged per the instructions).
07-14-2012, 08:43 PM | #3 |
Square
I would say do it your self and use the money for a good quality alignment when everything is done.
Squarebody Syndicate |
