Question for LockDoc...
Is it possible to match up cylinders to specific keys? Can I get door locks to match my ignition and barn doors or do I need to find a whole matching set?
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
What?
Re: Question for LockDoc...
Any good locksmith is able to do this.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#3 | |
The Older Generation
If the locks are original to the truck the following list applies. Be sure and check for a letter designation on your current keys in case the locks have been changed on your truck.. It may be stamped on the key or part of the part number on the key. 1967 = "A" blank 1968 = "C" blank 1969 = "E" blank 1970 = "J" blank 1971 = "A" blank 1972 = "C" blank You will notice that the '71 & '72 repeat the '67 & '68 keyways. Some of the reproduction lock cylinders have "universal" or "unrestricted" keyways so almost any key blank can be used with them. If your ignition key will fit into the door locks you want to use take the door locks and ignition key to your local locksmith and ask him what he would charge to do it. If you can't find door cylinders that will work with your key or a locksmith that wants to do it let me know. Chris is correct on this as long as the locksmith is provided with lock cylinders that are compatible. LockDoc
Thanks, guys. That was the answer I was hoping for. A few years ago I bought some parts from a '72 Burb. I got the wiring harness complete w/ ignition and the barn doors. I have been kicking myself ever since for not getting the driver and passenger doors too.
