Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-15-2012, 05:01 AM   #1
The_BullDog
The_BullDog's Avatar
Any ideas from you engine gurus?
I am thinking about putting a super charger on my 2 bolt main 350. I got it rebuilt about a year and a half ago. Still haven't reached the 500 mile brake in point. It has....
procomp heads and procomp intake manifold port matched
Aluminum Rocker Arms 1.5 Ratio,
Edelbrock 1721 - Edelbrock Performer RPM Street Fuel Pumps
Summit Camshaft, Hydraulic Flat Tappet, Duration 282/292, Lift .465/.488
holley 750 carb
Summit Hydraulic Flat Tappet Lifters
Proform Water Pump, Mechanical, Long, High-Volume
Also a summit 7qt oil pan w/ high vol pump
I also just put in a 3 core aluminum radiator with duel electric fans
I have a beefed up 700R4 trans behind it
The engine runs like a top HOWEVER.....We all know how these projects go, I have yet again changed the route I want to go with this thing.
So any info you guys can give on what I need to put a blower on that will kick it up some more. I am looking to have a truck to drive on saturday nights as well as be able to lite up anyone that wants to line up
What blower do you guys recommend?
Any other upgrades that I need to do?
Thanks for all your help here is a picture of the engine after I dropped it in.
The_BullDog is offline   Reply With Quote
Old 07-15-2012, 07:32 AM   #2
bubba353z
bubba353z's Avatar
Re: Any ideas from you engine gurus?
What's the compression ratio? Also, what kind of pistons, rods, and crank do you have?
The Weiand 144 is a nice small blower that would go in easily, and at low boost wouldn't kill a stock rotating assembly.
bubba353z is offline   Reply With Quote
Old 07-23-2012, 01:31 AM   #3
The_BullDog
Is that the only one that will work? I can get a 6-71 or a 8-71 for the same price as a 144 or 177. What would I have to upgrade to run a 6-71 or 8-71?
Old 07-23-2012, 06:43 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
A significant factor before moving forward are the answers to the earlier post about how much comnpression, what kind of crank, connecting rods and pistons your engine combo has.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-23-2012, 06:45 PM   #5
bubba353z
bubba353z's Avatar
You can run anything you want - 144, 6-71, 8-71, Procharger, Vortech. It just depends on what your goal is and how your engine is set up ( and your budget ).
Do you want to cut a hole in your hood for the big blower, or do you want a stealth approach?
If you want to make best use of any blower, you're going to need a strong bottom end - forged crank, rods, and pistons. You're going to want to get 4 bolt main caps installed - I'd recommend splayed caps.
Compression ratio will depend on how much boost you want to run, but 8 or 8.5 to 1 is a good target. I don't know what your cam specs are, but you'll probably want / need to change to a blower grind.
There are tons of other questions to be asked / answered - but these should get you started and thinking about just how far you want to go.
Old 08-03-2012, 02:45 AM   #6
The_BullDog
Thanks for the replys guys,
after a week and a half of trying to track down the engine builder I was informed that they used the stock crank and flat top pistons because of the age of the engine. He said that putting a blower on it would make it run like cr*p and that if thats what I really wanted I should just look into buying a already blown engine. so it looks like I will be runnin what I got for a while. Thanks for the help.
