Old 07-15-2012, 11:10 AM   #1
Cody63
Seat belts
Ok, now that I've gotten some work done on the truck it's time for some safety.
Anyone got any good links on some seat belt for the truck? I'm mainly interested in some lap belts.
Thanks,
Cody
Cody63 is offline   Reply With Quote
Old 07-15-2012, 07:37 PM   #2
pestwagon
Re: Seat belts
Same here...I have a 1962 wih no belts/anchor bolt holes at all...suggstions?
pestwagon is offline   Reply With Quote
Old 07-15-2012, 07:42 PM   #3
Larry64
Re: Seat belts
This website is great http://julianos.com/
Larry
Larry64 is offline   Reply With Quote
Old 07-15-2012, 07:47 PM   #4
66clow
66clow's Avatar
Re: Seat belts
California pacific has some nice belts I purchased. They have a wide variety
66clow is offline   Reply With Quote
Old 07-15-2012, 08:51 PM   #5
Breadstick
Re: Seat belts
I got mine from http://www.so-cal-az.com/. They were great for me.
Breadstick is offline   Reply With Quote
Old 07-16-2012, 12:05 AM   #6
CRGRS 66
CRGRS 66's Avatar
Re: Seat belts
A couple of helpful threads that I have saved for when I do my seat belts
http://67-72chevytrucks.com/vboard/s...d.php?t=531436
http://67-72chevytrucks.com/vboard/s...d.php?t=476066
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 07-16-2012, 01:26 AM   #7
pestwagon
Re: Seat belts
can anyone post the original factory instrructions for seat belt installation?
Old 07-16-2012, 11:53 AM   #8
Breadstick
Re: Seat belts
I'm pretty sure my 64 didn't come factory with seat belts. The PO had a driver's side lap belt, but when I replaced them with shoulder belts I found that they were not reinforced at all. He drilled a hole, put a bolt with a small washer on it, and tightened. If I would have wrecked, the seat belt would have been pretty much useless.
I did a lot of reading before I put mine in and I ordered the shoulder belts and mount kit from the link I posted above. The mount is basically a flat piece of steel with a bolt welded on it. Drill a hole in the superficial panel where I guess the b pillar would be in a truck (not sure what it's called). Then, just bolt the top portion in. Drill a hole in the floorboard by the seat and put a bolt through. Drill a hole in a flat piece of steel and put it on the underside of the floorboard to reinforce the seat belt. The kit I got has two pieces, so I ordered two and used a piece of steel I had in the garage for the latches.
The flat piece of steel with the bolt through it spreads out the force if you're in an accident and keeps the bolt from ripping through the floor with a lot of force applied.
Old 07-16-2012, 12:37 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Seat belts
