07-15-2012, 03:45 PM | #1 |
IS My HID Distributor going Bad?
Just recently there is a 4-5 second delay with the shut off when I turn the key off on my 350 ci /Hid equipped distributor. I have also noticed the tach is going haywire. It reads 3000-3500RPM at idle when it should read 700-900 RPM. Has anyone else had issues wit the stock early 80's style GM/ HID distributors?
The only changes that I made recently...I did install an electric fan . (draws 30 amps,have a new 105 amp new alternator.) |
07-15-2012, 03:50 PM | #2 |
But Found Her 25yrs Later!
Re: IS My HID Distributor going Bad?
I had an issue recently when moving some wires, where the truck (with HEI) would keep running after I turned the ignition off.
I somehow changed the connection to an always Hot lead. I moved the wire going to the HEI to a connection that died when I turn the ignition switch off. That solved my problem.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-15-2012, 03:54 PM | #3 |
Also, if you just changed the alternator, it may be wired now where it is causing a loop back to the ignition.
There's a thread here that mentions the alternator can feed back to the ignition even when the ignition is off in some wiring cases. The way I tested mine was I disconnected the alternator connections and yet the truck kept running. - That's how I eliminated the concern that it had anything to do with the alternator.
07-16-2012, 05:03 PM | #4 |
1962 C-10
Disconnect your electric fan and see if the problem goes away.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
07-19-2012, 09:18 PM | #5 |
if its a one wire alternator i have seen them feed back and cause the engine to continue to run explained here http://www.madelectrical.com/electri...evymain2.shtml
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice Last edited by bama63; 07-19-2012 at 09:24 PM. |
07-20-2012, 04:56 PM | #6 |
Thanks everyone for all of your help. Here is what I did to correct the problem: I wired in a 30 amp relay to the fan straight to the battery. I then ran a toggle switch to the dash so that I can manually control the cooling fan. problem solved. I think the draw from the electric cooling fan was interfering with my gauges ,HEI distributor etc when I had it tied into my fuse pannel. As soon as a shortend the length on the load side of the fan 12ga. wire- the tachometer read correctly and the ignition turned to the off position immediately killed the motor.
Now I just need to figure out why my temp guage is off so much? New gauges matching sending units etc. When I shoot the sending unit with my thermal gun- My temp gauge shows a 15 -20 degree error. I have the sending unit screwed right in next to the thermos stat . |
