71 lq4
Some pics of my Ls project.
![]() Join Date: Nov 2007
Re: 71 lq4
Sure is pretty!!
Re: 71 lq4
what color is on the frame?
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
Re: 71 lq4
Looking good! I like that dark red color on the engine.
Re: 71 lq4
The frame was sand blasted. Then a coat of zink oxide was baked on, then powder coated a house silver. The Motor should have been more copper in color, not super happy with it. (A local PPG dealer gave me the codes for their "copperhead" paint. My engine builder also has a paint shop so he mixed and painted the motor. not sure what to do now. Thinking I could go alittle more copper, and not notice with the motor tucked in the engine bay.
Re: 71 lq4
I'm 2 yrs into this project now, just held off on posting until I had something other then the same rusted frame, cab pics to show.
Fabricate till you "puke"
Re: 71 lq4
Very nice! What headers are you running? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: 71 lq4
awesome!...nice job.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: 71 lq4
Thank-You I'm running a set of sanderson silver ceramic coated blockhugger headers. I think some long tubes would have been better, but I bought the dissasembled 6.0, headers, and a new Howell Ind plug and play wire harness (with ecm), from a co-worker.
The headers look great with my silver frame, and fit nice with the CPP tubulare engine perches. |
Re: 71 lq4
...just wait till you drive it!...
Re: 71 lq4
Driving it seem so far out, that I haven't thought to much about it. Thats normal...right?
#12 | |
Re: 71 lq4
#13 |
Re: 71 lq4
Thanks. I'm running a 700r4 (with all but one bolt) I hade it built with a shift kit, heavy duty sink gears, and a 2000rpm stall. The crank didn't need the spacer although I made one, and the flywheel needed the holes opened alittle. I'm a Tool and Die Maker so that helps.
#14 |
Re: 71 lq4
Motor is coming out of frame today, and going to body shop to be repainted the correct color.
