Pics of transmission coolers
Looking for pics of transmission coolers on 55-59s that are running the stock radiator. Also looking for coments on how well they cool and what trans temps they are running. I have a good stock radiator i would like to use if possible.
Re: Pics of transmission coolers
This what I used. a B&M cooler.I am running a 350/350. I haven't been on the road yet but everythings seems ok running here.
Thanks for the pics. Do you have the part number for the cooler you bought? Did you install a trans temp guage?
It is a B&M 70266
Post #29 of my build thread. I've had no problems with it so far.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
I used a small condensing unit out of a commercial refer. From 85 to 2000 it was mounted in front of the radiator and worked with no problems. This time I am putting it under the passenger step. I left enough room for a thin electric fan if the temps get out of hand. I put in a tee to monitor the temp at the output line before the cooler. Because the frame, transmission, etc. flex so much off road I use hose connections between the hard lines and transmission.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I have a 11"x11" by 1.5" oil cooler out of a class a motor home i am thinking about using. I would have to move radiator in from support about a 3/4" to be able to mount it in front of radiator to clear cross bracing.
It's not quite what you were after, but here is a Fuel/Air heat exchanger from an USMC F/A-18. I have several work related "easter eggs" incorporated into my old truck. We would change these out when ever the fuel started to run hot on the jet. They cost Uncle Sam $27,349.61 each, but seems to keep my tranny fluid nice and cool.
#10 | |
Kim |
#11 | |
#12 | |
#13 |
SM&R code of PAOZZ, Dispose of at unit level. No turn-in required. Got me worried, and had to go pull up the pubs on NATEC to double-check. We wont talk about the dozens of cruise boxes filled with parts and PEB, stored in my garage during inspections. That's why I love working on this old truck. No rules or pubs, if I think it'll work, I try it and see if I like it.
#14 | |
![]() Let me know how you like it.
#15 |
How about the one in the bottom of the radiator ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#16 |
I guess the stock rad. did not come with a cooler, sorry I did not read the full comment !
