Old 07-15-2012, 07:54 PM   #1
crapy67
White wall terror
crapy67's Avatar
3 on the tree to an automatic
My question is will parts from a 69 fit my 71 like the cross member, pedal assembly and steering column, also will the trans tunnel be ok with a turbo 350 thanks in advance... Mark
crapy67 is offline   Reply With Quote
Old 07-15-2012, 08:14 PM   #2
chevynova22602
chevynova22602's Avatar
Re: 3 on the tree to an automatic
Yes it will work the holes for cross member should already be there as when they made the frame they stamped holes for auto trans but you will need to remove the front cross member that holds the 3 speed in hope this helped
chevynova22602 is offline   Reply With Quote
Old 07-16-2012, 04:30 PM   #3
crapy67
White wall terror
crapy67's Avatar
hey thanks for the info
Old 07-16-2012, 04:46 PM   #4
chevynova22602
No problem anytime
