Old 05-19-2003, 11:46 PM   #1
jays68yak
jays68yak's Avatar
Electric Fans
Well today my flexalite fan blew up. Two of the blades broke off, one slicing through the upper radiator hose. Now that I have to replace the fan I was thinking about putting an electric fan on. Would these cool the motor in 100 degree temps? The motor is stock, soon to have a new water pump since this one has a bad bearing. I have heard that a taurus fan works good, any one on this board have any experience with these? Heres a link for themTaurus Fan. Any other cheap setups that you guys know of?
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 05-19-2003, 11:48 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You able to get digi-pics of the damage left by the grenade flex fan? I'm always telling ppke bout these..I've witnessed one go through a hood.
It coulda been your head.
Old 05-20-2003, 12:19 AM   #3
jays68yak
jays68yak's Avatar
I have the fan and one of the blades still, also have the upper radiator hose. Ill get pics in a few days.
Old 05-20-2003, 03:01 AM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
i swear i'll never own a flex fan ....ain't worth the risk
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-20-2003, 04:04 AM   #5
Mudder
Mudder's Avatar
I just installed my 16 inch perma cool fan and shroud I got from Wes. It stays right around 183 degrees. hasn't been really hot here yet but I don't think I'll have a problem.
Mudder is offline   Reply With Quote
Old 05-20-2003, 04:17 AM   #6
73stepside
73stepside's Avatar
i would find an old thirdgen camaro z28. they had dual fans. you can rig one side to run all the time and have the other one kick in as asupplement for hot days. the rs camaros had one fan. mine works pretty good in the camaro, but it's so low to the ground, that it sucks up the heat from the roads. a truck shoold do fine with an electric fan. make sure you get one that has enough cfm to cool it down if you tow anything.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-20-2003, 10:21 AM   #7
jays68yak
jays68yak's Avatar
I currently use the camaro dual fan setup on my lemans. When I got them, they didnt come with a shroud so it doesnt do its best to cool. They are also expensive, unless you can get them at a picknpull.
TTT for me
Old 05-20-2003, 12:55 PM   #8
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used the search for you.
Here are a couple links to some previous good post about e-fans.
here
and here
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-20-2003, 05:24 PM   #9
Low69CST
I've heard same thing bout those flex fans, they definately are dangerous. I have a dual flexalite electric fan set up. I love it. I have a hopped up 400, it keeps it cool while i'm listening to it run in my dad shop.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-20-2003, 07:36 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Wes sells a nice looking set-up
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-20-2003, 09:57 PM   #11
jays68yak
jays68yak's Avatar
I do like the setup that wes sells and would love to have one....................but I need something cheap.
